Xantia TD Fuel Consumption
Xaccers
x 188
Re: Xantia TD Fuel Consumption
Unread post by Xaccers »
Peter.N. wrote:If these pumps work on the same principle of the old DPA pumps the damper is an anti stall device, it stops the throttle closing to quickly and momentarily shutting off the fuel which makes it stall of course.
That's fitted to the back of the pump to my knowledge, a rubber cushion that the back end of the arm hits.
The one on the front compresses when you put your foot down.
DIY sphere tool
Old-Guy
x 24
Unread post by Old-Guy »
Our 1.9TD used to average 42-43 mpg (local running around with the bulk of miles on motorway). Economising by cruising at 2,600 - 2,700rpm on motorway (instead of 3,000 rpm) fuel consumption has improved to about 45 mpg. Try either a can of diesel fuel system cleaner, or a tank-full of ordinary Shell diesel. I run ours exclusively on Shell as the choice locally is that or Pace (which is rarely more than ½p/L cheaper). If I fill up elsewhere, I look for cheap Shell.
Xaccers
x 188
Talking of Shell, most places I've seen it's either the cheapest or not often more than 1/2p more than other garages, and Cassy likes it nearly as much as veg.
DIY sphere tool
MPV
Unread post by MPV »
In my area Shell is usually a bit more expensive. With their loyalty scheme you can get 0.5 p/l in points, which brings it down a bit. I've found only the high grade Shell makes any difference to performance, but at 8p/l more it's not worth it.
Synergie XUD9 - the "Duck-billed-clatterbus"
lexi
x 134
Unread post by lexi »
42 mpg mostly on mine. They have become long in the tooth lest you are running veg. Extra price of diesel means the2.0 petrol is nearly on par with it .......and more oomph!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
KevMayer
Unread post by KevMayer »
From my recent experience with dirty inlet manifolds I'd get yourself some Wynn's EGR3 spray and give your manifold a treat.
Cheers, Kev
ecohouse1
x 3
Unread post by ecohouse1 »
Thanks lads
I checked the front brakes at the weekend and the pads on the o/s front were binding badly and I had to virtually chisel the pads out of the carrier!. All sanded/filed down and coppa greased and the difference is amazing - better more graduated braking and it feels faster. Will do the rear brakes as soon as I can but they don't seem to be binding.
Will run some diesel treatment and inlet manifold spray - by the way - what happens if you spray carb cleaner in - does that do the same job? :idea:
Cheers
Alan
