Fuel Warning light
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
addo wrote:
Halfway through that distance, parking nose uphill is at your peril! Done the silly thing twice.
Is your primer bulb sucking in air at the joins which allows the fuel to siphon back down the fuel line? sounds like it. it should hold a vacuum and stop this, I refitted mine with some silicone sealer in the ends and stopped the fuel running back, until I started running on veg and the engine hunted in cold weather then I swapped the primer bulb for an electric facet pump to pump the thicker veg oil until the engine warms up.
regards Nigel.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
No primer bulb; mine runs on 98 octane.
Loaded with tools and stopped on a decent incline for a few hours, the rear sinks appreciably - taking my residual fuel to back of the tank!
x 25
a one way valve strategically placed in the fuel line would defo fix that then.
regards Nigel.
