C5 CD Changer
viorelovidiu
Unread post by viorelovidiu »
it is on headunit module, you have to find customer mode then CD PLAYER option which is marked as "missing". switch it to present, confirm by F5 (programming) and log out of that module. cd changer will work :)
you dont have to modify settings in BSI.
here is a picture with my cd changer in c5 2005
http://imageshack.us/photo/my-images/37/dsc04364u.jpg
Citroen C5 2005 2.2 HDI 136cp Exclusive BVA
EX: Citroen C5 2005 2.0 HDI 138cp Exclusive
EX: Citroen C5 2005 2.0i 143cp SX
Clogzz
x 40
Unread post by Clogzz »
Something since too if it’s still any use, the label and socket of the stacker in my 2003 C5.
Image Image
ststech
Re: C5 CD Changer
Unread post by ststech »
hi i have an 06 c5 hdi 1.6 16v design i havent fitted a cd changer but a unit that emulates a cd changer and plays sd and usb memory sticks the problem is it plays ok all controls on stalk work but on the info panel it shows no track number or anything yet radio and the single disc cd is fine other than the missing display it works a treat just wondering if cd changer needs to be programmed to car but what baffles me is it plays fine ?????
2007 Citroen C4 grand picasso 2.0 hdi egs exclusive silver
1993 Citroen bx tzd estate silver
2008 Citroen C6 2.7hdi exclusive storm grey
ststech
Re: C5 CD Changer
problem solved tried lexia no luck but uninstalled unit then reinstalled and then activated with lexia 3 and mf display showing cd track and track time information :)
dieselnutjob
Re:
Unread post by dieselnutjob »
Clogzz wrote:Something since too if it’s still any use, the label and socket of the stacker in my 2003 C5.
Image Image
Two things
That looks exactly like the socket on the CD changer of my 607 (year 2001). I am trying to figure out why all the manufacturers of CD changer emulutors / adaptors / AUX in etc list a different part number for Peugeot to Citroen (like xcarlink, yatour etc)? When the CD changer is the same? or is it?
On the 607 the head unit to CD changer protocol changed when they went from VAN bus to CAN bus. upto 2005 was the RT2/RC2 which uses RD3 protocol. After 2005 it went CANbus and RD4 protocol. The two are not compatible, I strongly suspect the same is true of the C5.
