Speedo problems
x 8397
Re: Speedo problems
c.morewood wrote:Thats it Jim.. in the photo.. it'll rise with the ignition on to show temperature.. whether its true or not only a thermometer will prove.. just wish it wouldn't drop like that with ignition off.
Ahh right Chris, now I understand :) Sorry... My brain wasn’t functioning well last night...
That's got to be the mechanical end stop set wrong. MK2 gauges are odd as if you invert the pod the gauge needles will freely move all over the place but as soon as the pod is horizontal and right way up again the needles rest on their zero points. Thing is there's no obvious mechanical end stop as such so it'll be a case of fiddling until the needle sits in the right place when the pod is horizontal and right way up...
Is the sticky speedo now cured?
c.morewood
x 55
Re: Speedo problems
Unread post by c.morewood »
Success!! The temp needle wasn't pushed in far enough.. the needles need about 1-2mm clearance from the face of the dial.
Any less and the needle doesn't move, any more and it becomes floppy.
Yes the sticky speedo seems fine..(I just have to calibrate it against the satnav so I know exactly what speed I'm doing!!) time will tell. but at least I now how to sort it.. was a bit worried that it would take a while but I discovered some short cuts like not disconnecting the radio and its housing so this time I had it apart in 30 mins and back in about 45 ...difficult steering wheel housing!!
I've taken a few photos for a how to guide which I'll sort out later.
Thanks Jim :-D
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 8397
Re: Speedo problems
Excellent stuff Chris :-D =D>
