Brake Spring mod
Deanxm
x 87
Unread post by Deanxm »
red_dwarfers wrote:
Deanxm wrote:How many have taken the spring out then?
D
I sense another poll :lol:
:lol: so long as its not in french i dont care!
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
andmcit
x 30
Unread post by andmcit »
That'd add a bit of spice and make the proceedings more surreal though
wouldn't you say? Perfect for French car motoring plus we'll all learn that
little bit of French spannering lingo which may one day be crucial? No? :lol:
Nothing moves you like a Citroën
x 8462
I'm sure the French for "have you removed your brake spring ?" will prove extraordinarily useful Andrew...
You never know, in French everyday language it might even be rude....
andmcit
x 30
Hmmm you may be right there Jim;
"I've taken my spring out and stopping for me, it is much 'arder..."
in officer Crabtree Franglais
spider
x 77
Unread post by spider »
avez-vous retiré de votre ressort de frein? :?:
Andy.
Deanxm
x 87
keh?
D
XM Prestige PRV6 92
x 1486
Unread post by xantia_v6 »
I didn't like the original brakes with spring,
I didn't like the brakes with the spring replace with a solid tube.
I do like the brakes with the original spring pre-tensioned with a 3mm spacer (inside the plastic housing),
but I may be in a minority of one here.
x 8462
xantia_v6 wrote: but I may be in a minority of one here.
Not quite...
That bears out my findings. I've tried the spring mod on every Xantia I've owned and one (can't recall which now, except that I no longer have it) did not feel quite right springless and I ended up putting the spring back in.
I've never tried pre-loading the spring though - that has to be worth an experiment or two...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Who's going to be first and put a "pédale champignon" on their Xantia? :lol:
x 94
Unread post by citronut »
just lop the pedel off and replace it with a rubber dome :twisted: ,
then you will know what a true hydraulic citroen brakes should feel like,
regards malcolm
lexi
x 133
Unread post by lexi »
This is getting like a Hi Fi forum with people prefering valves and certain speaker cables :lol: :lol:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8462
lexi wrote:This is getting like a Hi Fi forum with people prefering valves and certain speaker cables :lol: :lol:
I just prefer valves :wink: :D
lexi
x 133
I changed the brake spring.......... too much harmonic distortion :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
mongoose100
Unread post by mongoose100 »
Ok, let me get this straight...
This said spring, assuming its only on MK2 cars? So removing this so called coil of metal will give me MK1 style braking?!?!?
Share the instructions guys!!!
Oh, question is tho, how hard is it to do?
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
andmcit
x 30
It's fittied on all Xantiae - removal will give you more immediate linear brake
application as per older more direct brakes Citroen. Try it, you may like it!
