Hi with a (big) smile
as acrowot suggested. the instlex.exe did the trick. now I'll try to install it on my laptop and complete the activation and hope for the best...
promise to update.
m a n y t h a n x
Problem with the Lexia
atr
- x 6
VertVega
- x 13
Get the smile back
The instructions are available in YouTube and may be soon will available in Wikipedia also
Here is one example (setup - update - activation) --> LEXIA AND PP2000
sent by a youtube user called scarymistake. Thanks to him.
Activation starts from 7:00 (total length 10:31)
There are many others, search words "Lexia Peugeot Planet System..."
Homer
- x 16
VertVega
- x 13
He has successfully installed Lexia, now it's the activation phaseHomer wrote:Are you sure you don't have extensions hidden and instead have a file called version.txt.txt
atr, here's a pdf document for you ---> How to activate Peugeot Planet Office
(Note that Peugeot Planet 2000 and Lexia are "same" except they have different logos
atr
- x 6
Hi
to my best judgement I've followed the instructions to the letter, but to no avail. the data that I put in the keygen is the data from the example pics from the instructions that are on the software cd and I suspect that's the reason why I"m getting the message that the activation code is incorrect, or something like that - error code 11. I've emailed the supplier in China, and as you guessed- they didn't even bother to answer.
hope to get helped.
hope to get helped.
acrowot
This KeyGen is a activation tool for LEXIA3 (same tool as the pp2000)
1. Custome code: 001
2. Software Version Number: LEXIA-345
*Attention: Please DO NOT iuput Other Version number such as LEXIA3-345.12 !
3. Input the right identifier of your pc number & Server request code that you get in the LEXIA3 activetion page.
atr this is the keygen text I got with mine, the customer code and the software version you already have, if I remember correctly you have to do a manual activation by pressing F3 to get the correct PC identifier and sever request code to put in the keygen, you have obviously got to be connected to the internet.
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
atr
- x 6
acrowot
atr, just a thought did you let it update the software to a later version as the keygen will not work then. At what point do you get the error code, is it when you have used the keygen and then entered the code it generates to validate?In the software version number are you putting LEXIA-345 AND NOT LEXIA3-345?
The Birdman
MikeT
- x 232
The Birdman
MikeT
- x 232
The Birdman
Sorry thought i had missed a bit of the thread.MikeT wrote:Erm, I did?The Birdman wrote:Who said anything about using a different activation code?MikeT wrote:You cannot use another activation code, it has to be unique to your installation/computer.![]()
Just in case, and going by the relevation of using codes from example pics and other keygens etc.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
MikeT
- x 232
I think you might haveThe Birdman wrote:Sorry thought i had missed a bit of the thread.MikeT wrote:Erm, I did?The Birdman wrote:
Who said anything about using a different activation code?![]()
The above would have resulted in someone elses activation code (or a fictious one at best).atr wrote: the data that I put in the keygen is the data from the example pics from the instructions that are on the software cd.
