C5 HDI clutch problem ?
cachaciero
x 9
Unread post by cachaciero »
Citroenmad wrote:It will be the same gearbox and clutch on the 140 Mondeo, its the same unit.
Well maybe, but having spent some time trawling through the web on a limited range of manufacturers, PSA and GM get lotsa hits Renault quite a few Toyota (Avensis) quite a few and Ford not so many.
Interestingly cylinder failure and contamination seem to figure quite highly as does failure of engine / gearbox shaft seals rarely does it appear to be the clutch itself, though there seem to be theorys about clutch plate material in the case of GM. In all cases one gets the feeling that manufactureres are being extremely reticent about coming clean in most cases, trying very hard not to meet their warranty requirements even point blank refusal in many cases even when it is plainly within warranty.
It does not look good to me and even taking into account that more people complain than say how good things are I smell a very dead whale, given that for all manufacturers clutches flywheels DMF etc. probably come from the same place.
So much so that having decided to give up automatic boxes for manual in the name of economy I now wonder if that might be false economy.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
steelcityuk
Unread post by steelcityuk »
Until running 'new' cars I've never had clutch judder or a brake lining coming unbonded.
Steve.
not applicable
x 1480
The clutch on my Mate's C5 2.0 HDi 138 had done 90k when we changed it in Jan. There was minimal 'wear' on the friction plate (<30%), but the DMF was goosed, and the release bearing fell in two. 'Wear' could be a subjective term! If you have a car with a DMF at all costs avoid overheating it - no holding it on the clutch on hills, avoid racing starts, and don't ride the clutch. It should last the life of the car then. Replacement is £££££ - my mate paid £400 for the 4 part clutch kit - and that was the cheapest he could get it :twisted:
Citroenmad
x 110
Unread post by Citroenmad »
RichardW wrote: If you have a car with a DMF at all costs avoid overheating it - no holding it on the clutch on hills, avoid racing starts, and don't ride the clutch.
Thats what i do, minimal use of the clutch, always have driven like that. A lot of people do drive with the above styles which might explain a rapid clutch failure rate on occasions.
Though the oil leaking onto the clutch is a different matter, that is a bit worrying, as there isnt much you can do to prevent that if a leak occurs it occurs.
The poeple posting in here with slipping clutches, does your clutch judder when pulling away too?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Xantidote
x 5
Unread post by Xantidote »
The majority (all?) modern diesels seem to have DMFs. I assume petrol engines have "ordinary" clutches? So maybe some of us will give up on diesels because the DMFs are not "fit for purpose", and the exorbitant price of regular DMF replacement
Martin
1995 Xantia TDLX (deceased :( )
Citroenmad
x 110
Yes most if not all modern diesels do have DMF.
However, its not just limited to diesels, many petrol cars have them now too.
03 Seat Arosa 1.0S
old'uns
x 127
Unread post by old'uns »
Xantidote wrote: So maybe some of us will give up on diesels because the DMFs are not "fit for purpose", and the exorbitant price of regular DMF replacement
god knows what's in mine then, DMF or 'normal',212k still on original clutch, no signs of giving up just yet, xx fingers.
Citroenmad
x 110
It should have a DMF, all HDI C5s do. If its original then it will still be on its DMF.
They are not all bad! Depends how they are treated im sure.
03 Seat Arosa 1.0S
x 5652
Long time coming but here is the promised photo of the slave cylinder:
(Clickable thumbail)
I couldn't locate the leads so downloaded to a laptop, dragged the photo's to a dongle, put the dongle in this computer and as I did - there are the leads, still connected and tucked under the computer, out of sight :(
Now if only I could find the dongle with the passwords on it :(
I had my DMF and clutch done at 120,00 miles. A mis-diagnosis as it turned out but they were close to needing it anyway.
I think I was at least partly responsible for slamming it into third on a steep downgrade while doing 90mph - every evening.
Saved wear and tear on the brakes :)
