GSF is closed till Wednesday so I am going to order online, can anyone advise if this is the part I am after for the accumulator sphere:
453PC0260 SPHERE-FRONT CENTRE XANTIA CENTRE FRONT 23.60
No mention of 2.1TD at all though.
Intermittent braking issues 98 Xantia 2.1TD
Xaccers
- x 188
Nope that's the hydractive centre sphere, for VSX spec and above cars.scooobydont wrote:GSF is closed till Wednesday so I am going to order online, can anyone advise if this is the part I am after for the accumulator sphere:
453PC0260 SPHERE-FRONT CENTRE Xantia CENTRE FRONT 23.60
You want:
453PC0011 ACCUMULATOR SPHERE XANTIA ACCUMULATOR 23.60
453PC0030 ANTISINK SPHERE-REAR XANTIA ANTI SINK (EXC ACTIVA) 23.60
453PC0470 PIPE SEAL 4.5MM LHM TYPE 4.5MM PIPE SEAL BX;XM;XANTIA;CX;GSA LHM 0.65
980PC0130 Total Hydraflush 5L for L All Citroens using LHM fluid 19.70
DIY sphere tool
DIY sphere tool
scooobydont
Thank you. OrderedXac wrote:Nope that's the hydractive centre sphere, for VSX spec and above cars.scooobydont wrote:GSF is closed till Wednesday so I am going to order online, can anyone advise if this is the part I am after for the accumulator sphere:
You want:
453PC0011 ACCUMULATOR SPHERE Xantia ACCUMULATOR 23.60
453PC0030 ANTISINK SPHERE-REAR Xantia ANTI SINK (EXC ACTIVA) 23.60
453PC0470 PIPE SEAL 4.5MM LHM TYPE 4.5MM PIPE SEAL BX;XM;Xantia;CX;GSA LHM 0.65
980PC0130 Total Hydraflush 5L for L All Citroëns using LHM fluid 19.70
scooobydont
sreid
Xantia Ride
Hi
Read with interest the tips on sphere,s etc. Nobody replied on a local indy (can I be so bold to ask what an Indy is ? ) And more importantly who can be recommended as one in the Glasgow area, as I too have some Xantia brake / ride issues And suspect needs a god overhaul but not at a main dealer. Any Indy,s in the Glasgow Area with contact detail please ?
Stevie
Stevie
S REID
Xaccers
- x 188
Indy=independant mechanic
DIY sphere tool
DIY sphere tool
scooobydont
Well bad weather at the weekend have delayed this again however, things got worse and the stop light and ABS came on solid. I had no option but to try another garage. The wheel bearing on the other side had collapsed.
That has now been replaced and there is now no rumbling or grinding noises anymore.
Driving home tonight and the ABS light flashed on again and the brake pedal went solid. All returned to normal after a hard press of the brake pedal.
Hopefully the weather will be remotely good this weekend and I can get the spheres on and the fluid replaced.
- x 1485
Re: Xantia Ride
Graham Harper is very good - a proper old school mechanic! Bit difficult to find off Argly Street: http://www.grahamharper.com/index.htmlsreid wrote: Any Indy,s in the Glasgow Area with contact detail please ?
Stevie
There's also a big Citroen Indy in Rutherglen.
scooobydont
Well, front sphere swapped and hyroflush is now in. Managed to break the chain on the draper chain wrench I had but found a screw on halfords filter remover that did the job. It took a LOT of force to get the old sphere off.
Will leave the hydroflush in for 1500miles and syphon it out (tastes lovely by the way
Since the wheel bearings have been swapped I now have the following problem. When the ABS light is on (which is most of the time) the brakes work fine. When the light goes out (for about 5mins then comes back on) the ABS kicks in when I press the brakes.
Thanks for everyones help so far, would never have been able to do this without everyones advice.
Citroenmad
- x 110
Sounds like a problem with one of the ABS sensors. A Lexia should give you more clues. I recall a few post on hear about the ABS cutting in during normal braking, i think DickieG had this issue. Was it not to do with the spacing of the ABS sensor or something?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
