Disabling coded keypad Peugeot 405
carlo14
Unread post by carlo14 »
I don't know the code! :(
Would it be simpler to swap for an ECU I have from an identical car, which I know the code for, or is it not as simple as that? (Is it easy to swap an ECU over?)
x 94
Unread post by citronut »
phine your local pug dealer and they should be able to get the code for you,
regards malcolm
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
In the 405 with the Simple ECU coding YES very simple
Ive no idea were the engine ECU is on the 405, but if you simply swap the ECU for the known coded one, then the Keypad will call for the code from the ECU...
Having an Unlocked ECU is very handy to have in reality... if you lock the coded one, swap it back over.
It will be a long 144 pin or so plug, with a small catch you pull back to lift the Harness plug off the top of the ECU...
Paul
A very sad...
1994 XM 2.1 d auto
Aurochs
Re: Disabling coded keypad Peugeot 405
Unread post by Aurochs »
Lets present what the original car manual says...
Aurochs
Lets see what the car Presentation Manual is saying...
Michel
Unread post by Michel »
I'm all for being helpful, but 9 years is a little long to wait for an answer.
x 1750
We've all done it - read a post and taken lots of trouble answering it.
Only to find out the query was from another era!
No calamity: history is what we can all learn from... :gh:
Michel
white exec wrote: 12 Dec 2019, 18:49 history is what we can all learn from... :gh:
I fear your theory will be disproved in the UK over the next 24 hours.. :roll:
x 1750
Let's see in the morning. You could be right . . . :shock:
Aurochs
Dear ones, I was upset to solve this issue several months ago, and I could find a solution NOWHERE online... My luck was a friend who has helped me with the instructions in the car Presentation Manual. Well, lets hope I am the last one who will be troubled with this... :)
Kind regards, Doru
briansib
Unread post by briansib »
hello
can i have an English Translated manual on this.
