Bumpy Ride Xantia - expensive fix?
hilldweller
Unread post by hilldweller »
Ok thanks for this. Much better to see it as it cuts out a lot of mechanical jargon. Am fetching the car back from the garage in the morning so will try to move the linkage, if I'm stumped I'll take a picture.
Hopefully I won't have to go down that route as the pit is 12 miles from my house and I don't have any ramps!
andmcit
x 30
Unread post by andmcit »
Speaking about useful threads lost in obscurity (I mean in the supasticky):
http://www.frenchcarforum.co.uk/forum/v ... hp?t=27122
Everything you'd need to know about sorting dodgy height correctors
thanks to Kev!
Andrew
x 94
Unread post by citronut »
moveing the manual hight control lever inside the car is very unlikely to free much of, as the main running fault will be the auto/self adjusting section of the mechanoisum,
the only way to sort this out long term is remoe the unit from the car and work and lube both of the spring loaded turrets till they flop about completly freely,
i dont know were that indy got his price from, but Martin at Pleiades will sell you a referbished H/C bracket/mount/linkage, when i bought one from him a couple of years ago it was £40 quid inc carridge and turned up the very next day,
regards malcolm
andmcit
x 30
Revisiting that parts illustration this morning with fresh eyes the parts
to look at are numbered item 6 (what many call the dog bone) and item 4
which is what the dogbone clips onto and for want of a simple description
is what gauges the current height position of the car's suspension by
'reading' the position of twist on the anti roll bar via bracket 4 that is linked
on one end with a small metal foot shown in the illustration.
Now I've seen this foot snap off with corrosion as the height corrector
mechanism seizes up and the roll bar still twists.
Andrew
andmcit
x 30
That thread by KeV I posted the link to is the best place to spend some
time working out what you need to look at and free up - when you start
to read it don't worry about the fact it's talking about a front corrector!
Both ends operate the same and a follow up discussing the rear is added!
Andrew
