Citroen Xsara 2.0 hdi Problems
jp6666
Re: Citroen Xsara 2.0 hdi Problems
Unread post by jp6666 »
Hi all
mine has the same problem
I took a switched live from bm34 and joined directly to live feed wire(pink) at front of fuel tank.
x 1955
Unread post by Paul-R »
That's basically what I did to our old Xsara to bypass a problem in the fusebox or power feed somewhere. As the wire was good from the fusebox to the pump I was able use most of the existing wiring (including the inertia switch) , all I had to do extra was a switched live feed through an extra fuse.
