Synergie remote key fob stopped working
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
That makes things clearer Lee
If you only have the one key carefully remove the innards from the plipper inc batterier.You should now be able to see the 2 small buttons on the top of it and the led at the front.Just try pressing the buttons to see if the led lights up.Sometimes you may have to squeeze the batteries together to get a good contact(the spring clips go weak).If you do get the led to light up then the remote is working,so try locking/unlocking car pointing the remote at the dome in the roof.If the led on the plip works but no joy in locking etc then try this.
turn key to pre ignition position where all lights on dash turn on.Point plip at dome and keep pressing the little buttons.Turn ignition off,open and shut door then try the remote.
This is the procedure i used i think :oops: but im sure someone will post up the official procedure :lol:
Colin
Lee D
Unread post by Lee D »
Many thanks will give it a go tomorrow.
paulhelliwell2
Re: Synergie remote key fob stopped working
Unread post by paulhelliwell2 »
i have same problem my board was broken so bought some of ebay but i can't get them to sink to the car
CITROEN
XSARA—XANTIA—SYNERGIE– EVASION
CENTRAL DOOR LOCK (1 BUTTON PLIP KEY)
Procedure
1. Ensure all doors are unlocked using the key.
2. Press and hold plip key button until LED stops flashing.
3. After releasing button, LED will light constantly.
4. Press the Plip Button once, and LED will extinguish.
5. Open the door and hold the Plip key near the Ignition switch, and
press the plip button one time.
6. Now turn the ignition ON, and wait 10 seconds then turn ignition
OFF.
7. After 5 seconds, Plip should now operate.
CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP KEY)
Procedure
2. Press and HOLD the large plip key button while the LED flashes continuously
for 20 seconds. After 20 seconds press the small deadlock button
once while still holding the large button.
3. The LED will stop flashing.
4. Release the large button and the LED will light constantly.
5. Press the large button one time, and the LED will go out.
6. Open the door and hold the Plip key near the Ignition switch, and
press the large plip button one time.
7. Now turn the ignition ON, and wait 10 seconds then turn ignition
OFF.
8. After 5 seconds, Plip should now operate.
have tried all the above but still no luck
The Birdman
Unread post by The Birdman »
Sounds like you need yours recoded Paul
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
paulhelliwell2
how go you do this or is it an expensive trip to citroen?
The Birdman
See if any of the Lexia owners on here life near you , they can help.
paulhelliwell2
cheers birdman i have already posted on lexia thanks for your help
paulhelliwell2
took car to a Citroen specialist today to get the remote's done but all he was going to was reprogram the keys he said i would be better off trying to see if there was any corrosion behind the dome but when i took the cover off there was nothing there?
is that where the remote sensor is or what else am i looking for?
thank you in advance
xmexclusive
Unread post by xmexclusive »
From my recollection of looking through the Citroen workshop manuals some Synergies got RF 2 button remote systems.
Saw this when I was researching for systems similar to the XM Mk2 RF setup.
The Xantia Mk2 also had a similar RF setup.
The receivers were TEXTON black boxes.
About 80 x 55 x 30mm with 9pin white double row plug.
As RF goes through metal they can be located in the dash.
Certainly so on an XM which also retains an empty IR slot in the roof light.
Even the IR wiring plug is present.
I never followed up Syn bits as they were not common in scrap yards.
The XM and Xantia setup looked very similar at first sight but proved to be a generic variation with incompatibilities.
Most important one was that Lexia programming only works with the Xantia not the XM.
Development order was XM first then Syn then Xantia so all three systems may be slightly different.
Will see if I can find the Syn and Xantia Mk2 remote workshop manuals to check this out.
John
Xmexclusive
paulhelliwell2
thank you John
