Having obviously bent the track rod, I suggested Alex also replace the rod end, given it's transmitted one hell of a bang and it's really a no-brainer and not expensive.
We will of course give the car a thorough 4-wheel alignment check but no need to pay someone to do it - just using a level bit of ground, two bits of string, a metal ruler, 4 axle stands and some patience.
Front toe can be adjusted using two bricks, two short straight bits of wood and a tape measure. All you need is a friend to hold the tape while you measure.
ZX Track Rod
Stunned Monkey
- x 94
