Help please? xantia estate suspension cold weather issue
DickieG
- Monaco's youngest playboy
- x 33
The link you describe is used to connect the height corrector to the anti roll bar. If its just the plastic link that's popped off simply push it back on and it may stay there, failing that the height corrector linkage may be stiff and require freeing off/lubrication. If the bent metal rod has snapped off then you can buy just that part separate from the height corrector.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
falling-out-with-my-car
- x 25
Thanks again DickieG,
some sanity at last, the plastic connector is still connected the bent metal rod has snapped or to put it a better way sheared in half.
thanks for the info it'll all help trying to describe it to pleiades later on.
regards Nigel.
regards Nigel.
DickieG
- x 33
The part number for the metal rod is 5291 14 (called Control lever by Citroën) but before fitting the new rod check that the height corrector mechanism is able to move freely otherwise the new rod or plastic link may also break.falling-out-with-my-car wrote:some sanity at last, the plastic connector is still connected the bent metal rod has snapped or to put it a better way sheared in half.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 25
Thanks DickieG,
Have taken note of the part number cheers. I guess the mechanism was ok because the car still lifts to top and drops to the bottom setting it just wont stay in the middle (ie normal driving level).
(would like to add I never thought for moment that it was something pleiades did Martin has done work on my xantia at very short notice and the service I have recieved has been Bl**dy marvellous). if you pay him a visit dont forget the chocky biscuits.
Nigel.
Nigel.
