C5 2.0 Hdi - No Power until 3500-4000rpm then whoosh....
x 1056
Unread post by wheeler »
I would agree that it is still the ECU controlls boost pressure.
Giving the turbo a direct vaccum (ie joining the two pipes at the turbo electrovalve) will give you constant full boost on a 110bhp 2.0 HDi, just pulling the pipe off will result in no boost at all.
The 2.2 HDi works the opposite way, if you disconnect the vac pipe from the turbo it rests at full boost.
The turbo electrovalves are quite common failures, The boost pressure sensors are not that common to give any trouble unless the little plastic pipe has been broken on it when the air filter has been changed, this is very easy to break if you are not very careful.
HDI
x 7
Unread post by HDI »
So the wastegate is held shut by vacuum instead of the actuator spring pressure ??!!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1056
Yes
HDI
x 7
Very strange !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Old-Guy
x 24
Unread post by Old-Guy »
Oh, I'm so glad I deliberately bought one of the last entirely mechanical 1.9XUTDs!
Electronic controls and automotive-quality electrical components - anything to save a penny (or centime) - are a recipe for problems in the long term.
cachaciero
x 9
Unread post by cachaciero »
Based upon my experiences with the 2.2 which runs on electronics and vacuum I would strongly recommend that if you have a problem with anything that has vacuum control first make sure that the actual vacuum is what you would expect i.e that there are no leaks as certainly on the 2.2 the flexible pipe joiners harden and crack causing variable vacuum losses.
cachaciero
