I'm certain the fans work because if the AC is turned on they run fine so that must rule out supply and relays. The sensor for the gauge is only used for the gauge , unplugging it has no effect on anything else.
Something called the 'bitron' sensor has been mentioned to me , any idea what that is ?
I'll test the solenoid valve tomorrow. The reason I asked about the electrical connections is that I suspect this car has had an engine change at sometime.
Xantia HDI 110 power loss problem / limp home ?
HDI
- x 7
- x 1487
Are you sure there's a problem with the rad fans?? It takes a long time to get them to come on in an HDi, especially at this time of year - only time I can think the temp has crept up enough on mine to get them on was sat in a traffic jam for about 2hours with 30+ on the temp gauge (SWMBO was having a funny about not having the A/C on for some reason
- then I eventually had enough and put it on, and was shortly afterwards greeted with the roar of full speed fans, which shook the whole car
I least I know they work I guess!).
We changed the coolant in my mates 306 HDi in spring a couple of years ago, and left it outside ticking over for well over 1/2 hour, and it was just struggling above 70° - no way it was going to get the fans on, so we took it out and ragged it instead!
HDI
- x 7
My assumption was that when the temp gauge was showing over 90 Deg they should have kicked in at low speed at least ? It does take some time for it to reach this temp admittedly.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 1487
HDI
- x 7
Good grief !! Just had a look in the Paynes manual and although it doesn't specify the fan cut in temp it does say the thermostat isn't fully open until 99 Deg C !!!
Well , if this is true I'm unlikely to ever get the fans working , even on the hottest day's in summer the temp never goes over the early 90's regardless of conditions !
I'll just have to get the AC regassed and use that for piece of mind !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
HDI
- x 7
Just removed that solenoid valve and tested it as far as I can. With no volts on the coil air passes through the valve , with 12 volts applied the solenoid clicks but air still passes through , so I would conclude that it is faulty.
Anyone know the cheapest supplier for these please ? Or is it dealer only ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 1487
HDI
- x 7
That did occur to me
Thats assuming the EGR one is ok ! When does the EGR valve activate anyway ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
