Xantia series 2 ABS problem.
reblack68
Unread post by reblack68 »
I believe you can replace the cable if you're handy with a soldering iron and the damage isn't too near the end. You have to get stranded co-ax cable and heatshrink.
Last time I looked for a sensor on ECP/GSF it was something like £50.
Richard
Care of a 1994 205 D.
MJM
Unread post by MJM »
Superloopy, thanks for the pointer. I bought one of the ebay items. It looked ok in the photo and examining it in the flesh against the old one I would say that it's OE. The mouldings look identical.
Anyway. tools out and wheel off. I measured the resistance of the new one, just for posterity and it was 1050 Ohms. The retaining bolts came free ok. :D Next job was to lay the new one in roughly the right path. It was a bit of a trial to get the connector through behind the fixed brake pipes but a bit of carefull pipe easing saw it into place :wink: I connected it up and did a quick check across the ecu pins, ok so far. The rest of the fitting went ok, the sensor needing a bit of a wiggle to seat it. The rotor looked ok too. Fix everything back, another resistance check and all ok. Start engine, abs light stays on. :(
Then I thought that I had read that the ecu needs to see a signal from the sensors before it resets. :idea: Load the dog in the car (and my wife :lol: ) and set off to dog training, one eye on the abs light. At near enough 20mph, out goes the light :D . At the next stop, all back to normal. :D On the way back, catch sight of orange light out of the corner of my eye :( Look down and grin, its only the low petrol light :)
I thought I would update the thread and also say thanks to everyone for all the assistance. its a fair time since I've had to find a fault and rectify it.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
As my VSX has now got the abs light on :twisted: :twisted: are the pin outs the same for series 1 and 2 abs ecus.
And true to form how exactly does one measure the resistance with a multi meter.... me and electrics :oops: :oops:
Colin
x 8386
I believe they're different Colin.
On the ABS ECU Multi Plug:
Left Front Pins 15 and 30
Left Rear Pins 19 and 28
Right Rear Pins 29 and 31
Right Front Pins 1 and 6
To measure, remove the ECU plug with ignition off and starting with the right front sensor, set you meter on ohms and measure between pins 1 and 6 of the plug. The polarity is not important but measure at the plug and not the ECU. Repeat for the remaining sensors on the appropriate pins
A good sensor will measure around 1089 ohms and it is critical. The sensor will either be open-circuit or reading a bit different from above. I've known them read 1190 ohms and not work.
If the sensor appears open circuit on test, re-test at the two pin connector on the end of the ABS sensor cables. the fronts are reasonably accessible on the front subframe but the rears are not :twisted:
Only ever disconnect and reconnect the ECU plug with ignition off.
VertVega
x 13
Unread post by VertVega »
Here are ABS pinout pics of both MK1 and MK2. They are different.
Second picture is from MK2: --> http://www.frenchcarforum.co.uk/forum/v ... hp?t=26012
(from Handy Hints & Tips)
x 94
Unread post by citronut »
MJM wrote
"Finger trouble"
is that a bit like mixing my tosey's TEA HE,
try GSF for the sensor
regards malcolm
admiral51
(Donor 2026)
x 391
Thankyou gentlemen another job to tackle this weekend now im fully armed with the destructions :lol: :lol:
Colin
Anychance the pinouts for the abs ECU could be made a sticky :wink:
x 5674
admiral51 wrote:Thankyou gentlemen another job to tackle this weekend now im fully armed with the destructions :lol: :lol:
Colin
:wink:
Done!
