Injector pump issue?
jonathan_dyane
Unread post by jonathan_dyane »
TBH, it's not what I would describe as a prime example. It is a 175 000 miler ex minicab, with scratched and dented bodywork (including the roof) and slightly distressed interior. On the plus point it drove well with good spheres, and is tested till November, and aside from perhaps rear discs and pads should MOT again easily. If I had more tools and somewhere to work I would do it over the weeked, but the street is currently my workshop, and in anycase I have just been offered an almost free 306 which I used to own and have done a lot of work on, so feel decamping to that would be a better plan.
The annoying thing was that I currently have the engine out of my BX, and only needed the Xantia to last another month or so in order to finish sorting it :-/
Jonathan
1986 Mercedes Benz 190D 2.5
1979 GS 1220 Club Estate awaiting more welding
1952 David Brown 30D awaiting new liners
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
will the xantia engine go in the bx ?
ignore that Jon, you said earlier you havent got the space etc to do big jobs...
John
jonathan_dyane
jgra1 wrote:will the xantia engine go in the bx ?
John
It would actually, but I already have an engine lined up for the BX, which is at my parents a couple of hundred miles away. I might pass the Xantia to a friend who needs an XUD engine; if anyone wants any Xantia bits give me a shout...
Jonathan
jgra1
(Donor 2021)
x 36
it's not a Mark 2 is it Jon?
x 8403
Jonathan,
Before you write it off as a dead loss, popr the clutch lever off and check the top bush on the clutch shaft has not collapsed and fallen down the shaft. It happened on my old 1.9TD.
The bush can be easily replaced withouth having the 'box off.
jonathan_dyane
Jim: Good thinking, but alas a little exploration has shown that the bush is still intact, and the problem is an internal one. It's a shame, but I think it is probably the end of the road for this particular Xantia, the fact that I have almost certainly killed the syncro on 1st from driving it home through rush hour with no clutch doesn't help either. If it had been a better example I would have kept it and changed the clutch, but as it is rather rough I think it will be a case of slow boat to China. At least I have a friend who might take the engine, and I will keep the Bosch IP and injectors for my BX.
John: Unfortunately it is a Mark 1.
Jonathan
