performance ugrades
ACTIVE8
x 6
Post by ACTIVE8 »
Koukku wrote:
CitroJim wrote: Speaking of the V6, I've just looked at the turbo conversion available for it :shock: how on earth do they find space for it, an intercooler and all the piping. Space and access is already at a premium as well as under-bonnet heat issues :twisted:
Hehe... I think the turbo kit is designed for a 406, and still they had to relocate the battery to make room for the turbo itself. Imagine all the hydraulics you'd have to move out of the way in an Activa...
So the thing is, it would limit their market, and therefore sales if it fitted less vehicles, so is it a fact that this kit would not fit an Xantia, and more specifically the Activa?
ACTIVA
Koukku
x 8
Post by Koukku »
I'm not saying it's impossible. Just difficult. :)
- Previously Activated -
KP
x 27
Post by KP »
Gareth do you use a Dash mounted boost controller or is it just a bleed valve in the engine bay??
Is it a Pressure Release Valve or Pressure Bleed Valve??
Do you run a boost guage as well??
Hsa anyone de-catted their Activa or fitted a swap out type section where the cat goes to see how much this helps??
What kind of oil are people using? Is half decent Castrol GTX any good if you stick to say changing it every 5k??
KP
x 27
Post by KP »
Also what tyres do people run?
I've had good experience in the past with soem Michelin Primacy's on my xantias(exclusive alloys) but on perfomance based cars used Goodyear Eagle F1 GSD3 but they wore out very very quickly.....
Has anyone tried any tires that are run flats at all for extra sidewall stiffness for even better cornering as im guessing when pushed the activa's cause a lot of sidewall flex??
Sl4yer
Post by Sl4yer »
KP wrote:Has anyone tried any tires that are run flats at all for extra sidewall stiffness for even better cornering as im guessing when pushed the activa's cause a lot of sidewall flex??
Not as much as a "regular" car from the pitcures I've seen. Makes sense since everything is kept in it's proper relationship to the road. Have a look at the road test vs. a Pug 306 S16 or the Audi A4 (the links are in the Activa area somewhere) and you'll see what I mean. The steel sprung cars almost roll the tyres off the rims!
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
XantiaMan
x 18
Post by XantiaMan »
KP wrote:Gareth do you use a Dash mounted boost controller or is it just a bleed valve in the engine bay??
I use a manual boost controller which is a ball+spring type, mounted in place of the original electronic boost solonoid.
Boost was set to around 12 psi but the ECU is very sensitive to slight spikes in boost. When air pressure outside is high and air temp low, boost can be a fraction too high enough to signal to the ECU to throw it into a fault code situation and run of default.
A very slight tweak down and its been fine, but beware of this if boost is set up in low pressure situations as boost will be higher when the atmospheric pressure is really high. I think it was 1039 mb !
I dont run a boost gauge except for diagnostics.
I use Silkolene 10w 40 oil from Oilman, really good quality stuff but any decent 10w 40 semi will do.
As for tyres, they need a degree of flex in the sidewalls to retain comfort but the high pressures on the Activa compensate for this. I wouldnt mess about with runflats or lower profiles, Citroen knew what they were doing and made a fantastic handling car out the box.
GSD3 is my top choice, i have them on the Maestro but dont recall them being available in 205-60 for the Activa.
I've got Falken on the front of mine, i wouldnt get any lower priced ones than these, they were only £40 a shot anyway. Its crucial to have a good quality tyre because of the cornering speeds the Activa is capable of, cheap tyres have a habit of gripping ok in the dry but dangerous in damp and wet conditions and they have very little progression or warning either.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
addo
Sara Watson's Stalker
x 95
Post by addo »
Curious which model of Falken - the 912s? They seem to make their range with good load indexes - appreciably higher than the recommended (here, at least) Michelin XM1. In itself, this could add some sidewall stiffness.
I've got C-Drives on the estate's trailing pair, and they have been light years ahead of the old Olympics or whatever they were. Looking forward to trying them on the front.
Cheers, Adam.
XantiaMan
x 18
Post by XantiaMan »
addo wrote:Curious which model of Falken - the 912s? They seem to make their range with good load indexes - appreciably higher than the recommended (here, at least) Michelin XM1. In itself, this could add some sidewall stiffness.
Cheers, Adam.
These ones here -
http://ssl.delti.com/cgi-bin/rshop.pl?d ... sowigan=So
2017 Fiesta ST
KP
x 27
Post by KP »
Where does the electronic boost control module sit??
Do you just remove the inlet and outlet boost pressure hoses and put them on the manual boost controller, or disconnect its electrical plug as well?
XantiaMan
x 18
Post by XantiaMan »
KP wrote:Where does the electronic boost control module sit??
It sits near the OSF Sphere. The hoses are taken off from the valve and fitted onto the new one. The multi-plug stays on as the ECU tries to intialise it when the ignition is switched on and will throw a code when it doesnt see it (it thinks its open circuit)
2017 Fiesta ST
SLYTZD
Post by SLYTZD »
How much difference has upping the boost made? And can you hear the turbo now?
Simon
'96 Xantia Activa in Silver 95,000
XantiaMan
x 18
Post by XantiaMan »
SLYTZD wrote:How much difference has upping the boost made? And can you hear the turbo now?
Made it more aggressive coming on boost, much more torque and a bit more bhp. Its only 3psi more than standard but because the boost comes in sooner and isnt regulated it feels overall more powerful and punchy. The turbo is still virtually inaudible except down narrow lanes.
2017 Fiesta ST
addo
x 95
Post by addo »
They're the same Falkens as I fitted to the 405 (albeit in 195/55/15; paid £53 F&B). They seemed quite sticky even brand new - I'll take grip over wear any day.
KP
x 27
Post by KP »
I have to have an equal amount as some years i've had the car cover 30k miles.... The coupe used to get a lot of miles and every 4 months ate a set of fronts and every 8 the rears would need doing.....
If you really want sticky try some Dunlop S01J's i think they are called. barely road legel when new they are the stickiest tyres i've come across in the summer.
slyv12
power?
Post by slyv12 »
What sort of power can the standard engine take on the activa?
I'm thinking of a t28 turbo, injectors, megasquirt ecu and a free flow exhaust with a 200cell cat.
