xantia cuttin out
swadger25
Unread post by swadger25 »
yes have cleaned the pick up in tank. have found a sensor that is on the side of engine next to the vacum pump ,not sure wat its called ,there a pipe comes from the vacum pump in to this then goes down back of engine to the turbo. this is broken as the small pipe was snapped off.
swadger25
got car runnin now. changed the leak off pipes and the blanker 1 all the fuel hose on engine side any way. found the leak from filter housing so replacement now on, and found that boost solinoid was faulty and broken so got one of those. thanks citroenjim you was most helpful as well as rest. still interestedin changing to bosch pump stuff.this seems to have cured the problem fpr the moment
