Hi Mike,MikeT wrote:Latest observations - STOP light comes on, after just a brief stop of 15 minutes or so, for several seconds while the car raises a little. This was a rare occurence before.
Theres nothing wrong with the stop light coming on for a few seconds after the car has been parked for 15 minutes - when you get into the car the height will drop, the height correctors will open trying to lift the car, this will draw on the pressure reserve in the accumulator and cause its pressure to drop below the point where the light comes on. (Approximately 80 - 100 bars)
It's also normal for the suspension to stay up longer, lift quicker, light go out sooner etc after spheres or LHM has been recently changed, and then gradually over a few weeks it deteriorates and then stabalizes. Nobody quite knows why, but they all do it.
If you're worried about the light taking a few seconds to go out after parking for a while you're chasing ghosts.
Hmm, are you sure it has the correct spheres fitted ? The ride should not feel boaty....Thought it might also be worth adding - I always thought the ride was a bit "boaty". There's a rippling (undulating) road nearby [troughs are in line with the drains at the kerb] that, while mildly accelerating from 20 to 40,I feel like I'm on a carousel ride! Altering acceleration does little to change that except amplify it.
This just screams out poor tyres and/or wrong spheres to me...I find conering at high speed (over 50mph) quite twitchy. It's easy to get the front to squeal on moderate to hard acceleration/cornering too.
I've driven cars at mad speeds before and you can get a certain confidence as you realise the limits but I get nervous at 70+ when approaching bends in the Xantia. Without the ABS currently working I just know that a heavy touch on the brakes when cornering will invoke a spin.
The front on mine doesn't squeal at all even on hard cornering, and the rear NEVER feels like it's going to come loose and spin. (I have 205/60/R15 Michelin XM1's on mine)
If it feels like its tail happy you've definately got problems, Xantia's just aren't like that. (Or Citroen's in general) The only things I can think of that would do that is if the rear suspension was either very hard or extremely soft, or the rear tyres were crap. Perhaps if the rear passive steering bushes were very badly worn you might get a similar effect.
Don't understand what you mean there, can you elaborate ?Even at lower speeds and heavy cornering I have to re-adjust (sometimes a more than once) the steering as the suspension levels back.
Sounds bad. Needs looking into...I get the impression the rear is all too ready to want to overtake the front given enough provocation but I have yet to prove that
Start by locating the part numbers on the spheres if possible and posting them onto the forum and someone can look them up for you and tell you if they're the right spheres or not. It's not uncommon for people to fit the wrong ones, and depending on how wrong they are it can have disasterous results on the handling and stability of the car.
Common mistakes are fitting estate rear spheres to the hatchback (makes the rear too soft) or fitting normal strut spheres on a Hydractive 2 model. (also makes it too soft)
Also have a good look at your rear tyres... and perhaps post here what size and type they are...not all kinds of tyres suit the characteristics of Hydropneumatic suspension...
Regards,
Simon
