Aaarrrggghhhh!!!!!
Its all gone pete tong!
I thought i had sorted the PR problem, but i now find that, although the leak from the end cup has stopped, it now leaks from the pipe connections on the top of the unit, but only when the engine is stopped ( when running, there is no leak at all!). I have used new seals, coated in LHM before assembly. Is it possible I may have overtightened the unions?
I did do them up very tightly!
new member, new to citroen, need help!
Stewart(oily)
- x 35
pete the bus
- x 8272
It's one of those things where what you would naturally think and what happens is totally at odds. It seems totally right and logical that a pipe carrying some 170 bars of pressure needs to be tight.
In fact, how the seals work is they expand under the pressure of the LHM and thus seal very tightly. The higher the pressure, the more better they seal. You have seen this happening when they leak when the engine is stopped but seal when it is running.
Sphere seals work in the same way.
It's a bit like plumbing and compression fittings. Nip them up lightly and if they leak, nip 'em up a little more.
jeremy
I agree entirely with what's been said. The correct torque figures are probably below what a normal torque wrench will read - but are in fact the sort of figure you would achieve with a normal length open-ended spanner at a comfortable tightness (ie no danger of it slipping)
A couple of points - its very important that the pipe goes straight into the hole and is not strained or tipped over at an angle and pipes can crack if they are not properly secured. If they crack you get drips at first - then the deluge.
New pipes from Citroen generally aren't expensive and are beautifully bent to fit - they really are a work of art!
jeremy
Quackers
- x 17
Re: new member, new to citroen, need help!
Try the Activa model Xantiapete the bus wrote: But despite all this...I LIKE THE CAR!!!
Xaccers
- x 186
I wondered why you were making those noises on the way to Northampton yesterday Jim!Quackers wrote:Try the Activa model Xantiapete the bus wrote: But despite all this...I LIKE THE CAR!!!Now that is a love hate relationship! But handles like no other car on earth, o god its orgasmic when it corners......
DIY sphere tool
DIY sphere tool
- x 8272
Xac wrote:I wondered why you were making those noises on the way to Northampton yesterday!Quackers wrote:Try the Activa model Xantiapete the bus wrote: But despite all this...I LIKE THE CAR!!!Now that is a love hate relationship! But handles like no other car on earth, o god its orgasmic when it corners......
Quackers, you never made a truer statement about Activas and a love-hate relationship
wrinklet1
pete the bus
I have'nt been able to do anything with the car this weekend, as I've been partying
I did remove the old seals and cleaned the 2nd hand PR thoroughly before fitting. Hopefully it's a case of overtightening and can be easily rectified. Will have a look tomorrow.
One new thing to add to the list of problems
- its now developed an oil leak. Haven't had chance to find out where from - (possibly the rocker cover. Is this a common problem?)
Stewart(oily)
- x 35
pete the bus
UPDATE:
Re-seated pipes and seals on the PR. No more leaks, engine running or not-running
Put it in for an MOT - and PASSED
3 advisorys though - steering column top bearing slightly worn
offside front (rack knuckle) ball joint has slight play
oil leak
Not too bad!
2 things to do 1st though, 1. new anti-sink sphere
2. Adjust the clutch ( there is no play whatsoever, and occasionally it slips slightly. I am hoping it is out of adjustment, and not the clutch wearing!. Any help on how to adjust the clutch, as I cant see any adjusting points under the bonnet!)
oil leak
Not too bad!
- x 1477
pete the bus
