Right chaps,
The rear spheres finally gave in early this morning. In the end, I soaked the joint in Rustola penetrating oil over night, put the car on ramps, pumped the suspension up to top height, gave them both a wack with a mallet, then cracked them of using a strap wrench.
Success at last!! Fitted new spheres and now its like driving a magic carpet!
Thanks all for your help
Regards
Phil
Rear sphere removal nightmare
phil_box
Right chaps,
Regards
Phil
Regards
Phil
phil_box
Right chaps,
Regards
Phil
Regards
Phil
phil_box
Right chaps,
Regards
Phil
Regards
Phil
phil_box
Right chaps,
Regards
Phil
Regards
Phil
phil_box
Right chaps,
Regards
Phil
Regards
Phil
Gregg1100
- x 5
Rear sphere Removal nightmare
Hi Phil,
You need one of these;
http://img.photobucket.com/albums/v676/ ... 010423.jpg
If you need measurements to knock one up, feel free to email.
If you can't get sphere undone on car, you will never do it with it on bench. Try loading boot with people when suspension on highest setting, as described by others here, then with one of your improvisations, you should be able to crack the seal.
Hope this helps,
Greg
Hope this helps,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
phil_box
Right chaps,
Regards
Regards
Homer
- x 16
Activa may be different.KevMayer wrote:Homer,
I'll jack the Activa up tomorrow and check the feed pipes just to make sure.
You do realise I won't be able to sleep tonight.....
Kev
It was a BX I broke the pipe on (following the BOL instructions) and nearly did the same to a non-hydractive Xantia (with the suspension on high).
phil_box
Right chaps,
Regards
Phil Box
Regards
Phil Box
- x 94
Stempy
He's just so pleased it's done he can't stop posting about itcitronut wrote:looks like the dreaded debug mod has been working overtime on your posts phil box,or is it you have a stamer,unless its the recoil from the club hammer,well done all it realy takes is a bit of percy whats it
regards malcolm
Lexia ponce
Lexia ponce
