best oil for xantia 2.1td with 186k
jeremy
Unread post by jeremy »
Ben - do I take it that the problem is that they are too tall to fit underneath - and so you are looking for some that are squatter than normal?
jeremy
Rostami
Unread post by Rostami »
On the Hdi, citroen recomends Quartz 7000 semi synthetic, at 15000km or 10000km changes.
I have been using Quartz9000, fully synthetic. 5W40 or so. And the oil is fine after 15 000km.
The Hdi engine is am improvement of the XUD so I see no big differences, and as Anders says, they are no rocket engines.
In my case, most km are done on the highway, and I am very carefull with the engine.
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
mezuk04
Unread post by mezuk04 »
I do oil changes every 5k as my weekly mileage is at least 400 for work and then whatever at the weekend, I use to use the expensive Magnatec oil for over a year with the ZX and then recently started using the cheaper bigger bottle from Morrisons supermarket, its about £7 and you get more and I cant say I have noticed any difference.
Obviously when I have my own car again whenever that may be and hopefully I will have a Citroen again I will still use the cheap oil every 5k
Volkswagen Golf 59' 1.6TD S :(
Insect
Unread post by Insect »
My ZX TD has done 180,000 miles of its current 235,000 on Halfords semi-synthetic 10w-40 and Halfords filters, both changed every 6,000 miles.
ex-ZX TD Estate owner - (309,000 miles on the original engine and turbo) now risking a Renault.
