ZX windscreen washers
mezuk04
np
mezuk04
James.UK
Oeerr this is getting confusing.
So the Xsara set wont fit a ZX? But the 407 type will fit a Xantia that has underslung jet fittings with a bit of modification, but we still don't know if they will fit on a ZX?
Is the fitting on a Xantia the same as that on a ZX? anyone happen to know?
My Citroen dealer still hasn't got them in, and when I phoned the local Peugeot dealer to order a pair of 407 mist jets they want me to go in and pay before they will place the order!! the jets are £2.70 each! lol. Too expensive an item for Peugeot to risk having in stock? dohh.
Looks as though I will have to wait till Citroen get mine for me (Xsara type) and then see if i can get them to fit, I will let you know what happens.
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
np
James.UK
I have a pair of Xsara mist jets in front of me. The water entry is from the underside at right angles to the exit holes and therefore makes fitting this jet underslung very difficult, it does look as though it would be fairly easy to fit it to the peugeot 306 which is a push in from the top type fitting.
The little locking lugs (arrow head shaped) are each side of the entry pipe, so also at right angles to the jet exit holes.
As it's very windy here at the moment I dont want to risk having the bonnet blow against the w/screen so will leave trying to fix it untill the wind eases off. Maybe tomorrow..
The Xsara mist jets cost (new) £1.97p each, £3.94p for the pair, bought from my local (main) Citroen dealer..
rossnunn
James.UK as I said the Xsara's fit the 306 perfectly with no mods, they just clip into place.
np, thanks for that I'll take it down the local dealers & see if they have them in stock.
I've had a quick look at the ZX ones compared to the Xantia Ph1 & 2 & I rekon they're a direct swap, if not its damn close, so I'd say the 407 ones would fit to the ZX no worries
mezuk04
Well i have ordered the Peugeot 407's for my Xantia Mk1 and was just over a fiver so im looking forward to the misting of the car, picking them up monday afternoon so we shall see what comes of this
Probably 2 sets of mist washers that dont fit the car...
Anyone interested in my Xsara Mist Jets since i dont have a Xsara hehehehe, couple of quid????
Volkswagen Golf 59' 1.6TD S
jeremy
np
np
davehughes
I had mist jets on my MK5 Golf. They are excellent! a must have for the serious driver
I'm definately getting some for my Xantia now that I know they fit
Has anyone tried fitting those pug wipers with the jets on the actual wiper?
A friend of mine fitted some off a 405 on to a D reg 205 successfully......
1993 Citroen Xantia 1.9 SX TD 120,000 Metallic Grey
