Ah! the ideal gas equation now that takes me back, still dont fancy using petrol as hydroflush though, at a push perhaps diluting LHM with some kerosene or even white spirit, though I would not run it for long (I had Hydraflush in for 2k miles approx)as the lubrication would be suspect as well as potential flammability issues.
Stewart
Cleaning hydraulics rapid question
FrenchLeave
BonceChops
oilyspanner
FrenchLeave
I know we're getting a bit off subject, but I'm still intrigued by the reason why Citroen used nitrogen in their spheres. It certainly wasn't for fire suppression and as for the comments about springing rates, water vapour in air and cheapness, it doesn't sound convincing. After all, air is used as the springing medium in the oleopneumatic legs on aircraft undercarriages and they fly at 11000 metres (temperature -56 dec C.). The air is dried before charging by passing over silica gel crystals.
406 V6
madasafish
JohnW
I'm sure that there's been a thread about nitrogen in spheres, a year or so back. It is typically, if not universally used in inflatable rubber packers for borehole testing, and I've always presumed it is because it doesn't react with the rubber and is available dry. With PV=nRT operating, it wouldn't be different from dry air in "springing" in my view either.
As for petrol or diesel in the system to clean it out..... Aaarggghhh! I've seen a pinhole leak in a high pressure line and, if you want a really good explosion, try it with a flammable liquid. That's why fuel injection works so well in the combustion chamber....
JohnW
JohnW
