Peugeot 207 Vti crank no start ongoing issue
max1
(Donor 2017)
x 5
Re: Peugeot 207 Vti crank no start ongoing issue
Unread post by max1 »
Thanks Mike. Yeah i think I'm getting close to being pretty much out of options now. A few pages back ( viewtopic.php?f=4&t=58439&start=90 ) you posted this test you did with the cam/crank sensor & @darbuck mentioned it looked strange, I wonder if this is a clue. Although since then I can see the crank speed in diagbox so am not sure.
I've pretty much ruled out a fuel problem. I have good spark. Airways are clear. Compression sounds ok. That leaves timing or some other weird electrical fault linked to timing or perhaps the immobiliser & of course this strange 3.3v.
I wonder if you or anyone here knows how the ignition timing works for this engine & what I could possibly check for in diagbox ?
MikeT
x 232
Unread post by MikeT »
I'm more a diesel man Max and even then no expert.
You say there's a good spark when cranking yet when you added fuel there was no signs of combustion. Have you checked the plugs for flooding?
max1
(Donor 2017)
x 5
I haven't as I need that special spark plug tool, I should probably get one! If it was flooded & I left it & didn't crank it for a few days, wouldn't it have dried out by then ?
MikeT
x 232
I would get the tool, max.
max1
(Donor 2017)
x 5
Ok. Thanks for all your help Mike, hope your on the mend.
MikeT
x 232
Not doing too bad thanks mate :)
My reasoning is, if it's flooding when cranking doesn't matter how long you leave it to evaporate. As the ECT appears to be our only clue so far the spark plugs may tell us more and could even do with cleaning, regapping or replacing while you're at it.
If I know what I'm looking for, I may well already have a suitable socket among my tools.
max1
(Donor 2017)
x 5
Glad your on the mend Mike. The socket is this one - https://www.ebay.co.uk/itm/Thin-Walled- ... 33806752c3. I have tried starting it in clear flood mode (throttle pedal to the floor) but no good.
MikeT
x 232
I forget about that clear flood mode option.
Hmm, don't think I've got any thin-walled deep sockets like that but it's not expensive and there's cheaper ones out there if you've got to watch the pennies.
https://www.ebay.co.uk/p/14mm-Spark-Plu ... 008&chn=ps
Meanwhile, if you're planning to take another look at it, I've got to go to Pokesdown sometime and could swing by yours for a cuppa :)
max1
(Donor 2017)
x 5
Cheers Mike am away for a bit but will bear that in mind when i get back. Still thinking if there is any way how to get this 3.3v verified somehow!
max1
(Donor 2017)
x 5
Pleased to report that it's started & running great now! Once i finally got the correct tool to get the plugs out i found they were not in a good condition. New plugs & some oil into the cylinders to get compression back (it must have been flooded) & she started up straight away. So all along that was the problem, the battery disconnection & 3.3V were massive red herrings! Ah well, at least now I know 100% more about engines than I did before :lol: :lol: So looks like the mysterious 3.3V is in fact correct. I did ask the question on an electronics forum & it was confirmed there that 3.3V is indeed a standard processor supply voltage, along with 5V.
Looks like as well i have a leaky rocker cover gasket as 3 of the 4 plug threads were covered in oil, so will probably be good to get that replaced. Also need to fix the non working horn now as well, hopefully will be a breeze though compared!
Thanks everyone for all your help, this is a great forum.
MikeT
x 232
max1 wrote: 12 Apr 2019, 16:53 Pleased to report that it's started & running great now! Once i finally got the correct tool to get the plugs out i found they were not in a good condition. New plugs & some oil into the cylinders to get compression back (it must have been flooded) & she started up straight away. So all along that was the problem, the battery disconnection & 3.3V were massive red herrings! Ah well, at least now I know 100% more about engines than I did before :lol: :lol: So looks like the mysterious 3.3V is in fact correct. I did ask the question on an electronics forum & it was confirmed there that 3.3V is indeed a standard processor supply voltage, along with 5V.
That's great news, max and thanks for reporting back.
wheeler wrote: 29 Aug 2017, 10:56 Also check the engine is not now flooded, this often happens with a faulty CTS as it can massively over fuel. Get the spark plugs out & heat them up with a blow torch & se if you can get it to fire up.
That was almost 2 years ago.. I'm kicking myself I didn't have a suitable socket back then as I know the sparkies can tell you so much about an engine, even when they're running right.
I'd imagine if they were that bad to cause a non-start, the car will absolutely love the new plugs. Enjoy.
vicstudio
New User
Unread post by vicstudio »
I have quite similar problem with my Citroen C4 Picasso Mk2 1.6 vti. Everything started after changing the spark plugs and switching the Camshaft positon sensors. Engine stopped, after that crank but no start. I check the wires conecting to camshaft position sensors end there is a short somewhere. Can anyone help with a wire diagram? Thank you
