Merged Lexia & Diagbox threads
MikeT
x 232
Re: Merged Lexia & Diagbox threads
Unread post by MikeT »
GiveMeABreak wrote:Yes, got that Mike, I really don't know what else to suggest, I still think the Netbook hardware maybe borderline. Shame you can't put it to the test by installing on another system.
Just to update, I think you're on the right track Marc. The netbook must be lacking in either hardware or software, I've not been able yet to determine which but I'm hoping it's the latter as monitoring the resources when the fault occurs shows no spikes or other tells the hardware can't keep up, it simply refuses to proceed, waiting for something.
Taking your advice, I've since managed to install Diagbox v7.65 and both Citroen and Peugeot Dockbackup/Sedre on the not-so-portable laptop as a virtual XP box. All's working as expected so I at least have a backup option (once I find the cigarette lighter power adapter for it!).
x 6956
Excellent Mike - back in business!
christof1980
Unread post by christof1980 »
Hi
I am new to the forum. Does anybody have a Lexia near Bolton Greater Manchester? I need my steering wheel angle sensor calibrating.
Thankyou in Advance.
x 5671
christof1980 wrote:Hi
:welc:
Check the list and map here
christof1980
Thankyou noone near me unfortunately
renagade
x 10
Unread post by renagade »
Hi Guy's
For one reason or another I have given up on trying to get my Lexia to work with my car ( 2011 1.6 e-hdi egs6 ).I know what you are telling me to do but pension won't stretch that far just of late and know the bill for the gear box who know's.
Keep up the good work Guy's.
There are so many roads to travel but so little time, (Paul Cofield )
sutty86
Unread post by sutty86 »
Trying to install lexia 3 absolute ballache on a Acer netbook , running xp
Any hints on best version etc
x 6956
First thing is back to basics - netbooks are not the best devices for running this - they generally don't have the resources needed to run Diagbox well.
1) What spec, CPU, RAM and Graphics card do you have?
2) What version of Diagbox do you have and how far have you got with the installation and lastly:
3) What issues are you having?
sutty86
Intel atom n570 1.66ghz dual core
2gb ram
320gb HDD
Basic Intel graphics
Its an eee PC battery lasts forever (genuinely)
Using lexia 3 v45
For use with xsara picasso
x 6956
For Diagbox the CPU recommendation for Diagbox is usually 2GHz or higher - I assume this is a stand alone installation of Lexia.. Most of us here use Diagbox now, that contains Lexia embedded within, which will launch automatically if required.
sutty86
GiveMeABreak wrote: 12 Jun 2017, 11:51 For Diagbox the CPU recommendation for Diagbox is usually 2GHz or higher - I assume this is a stand alone installation of Lexia.. Most of us here use Diagbox now, that contains Lexia embedded within, which will launch automatically if required.
Great I have a Alienware gaming laptop but running windows 10 64x will that install diagbox and which is the best version to download seems like there is loads
x 6956
No, you can't install it on a 64 Bit system Sutty, unless you have a virtual machine set up running a 32 bit version of XP or Windows 7. Lexia is a 16 Bit app and won't run under a 64 bit OS unless in a VM as mentioned.
Now I make no promises that it will work on your Netbook system, but I have the Diagbox V7 files if you want to have a go. They are quite large, but let me know via PM and I'll get you the instructions and the links.
MikeT
x 232
As attested earlier Sutty, I have diagbox (currently v7.65) running on an Acer netbook with similar spec to yours. It does most of what I want without a problem, a bit slow at times but that's to be expected with any apps, even the OS itself on such a low-grade spec. The biggest problem I've found is that lexia won't graph and show recorded live data but otherwise, no isssues that I'm aware of and, as you say, the battery life is several hours.
sutty86
Right managed to get lexia on have faults on anti lock brakes and injection,aircon
Cannot get into injection though , I click on validate ecu and it just hangs
Might have to try diagbox
easydiagnostics
Unread post by easydiagnostics »
Hello French Car Forum Members
this is a post to let you all know that the website has now been fully upgraded from html5 to html6. This allows the site to run faster but now gives us full ability to offer the discount code we promised to FCF members earlier.
Any member looking to purchase a lexia kit can simply add it to their basket, checkout and enter this code below into promo code box
FCFMEMBER15.........this will automaticallly deduct 15% from the original price.
hope this helps and sorry for the delay in getting this code to members.
