Citrojim's V6 Conversion
x 1469
Re: Citrojim's V6 Conversion
Unread post by xantia_v6 »
CitroJim wrote: I have acquired perhaps the most important part for the project to allow it to meaningfully progress. A complete S1 Xantia V6 donor :-D
Is it one that we know?
[Edit] Just saw on your other thread that it is.
x 8422
superloopy wrote:
bxzx16v wrote:I really look forward to some updates and pics Jim.
Mark
Me too ... i've got a V6 and a couple of Activae which could come in handy if i can get enough pics-on help [emoji6]
I'll do as may pictures as possible Mike :-D
Can we then expect to see another Activa V6 on the road then?
x 8422
It's certainly a way of curing the water leak Mike :lol:
x 1493
Nice work :mrgreen:
I foresee a picture of a ESJ9 engine a la practical classics all spread out, with caption "Well I set off to re-seal the camboxes, but sort of just kept going because I wanted to check for piston skirt wear. Now I have an ESJ9 in a 1000 pieces. Anyone got an instruction book to put it back together?" :-D :rofl2:
x 8422
RichardW wrote:Anyone got an instruction book to put it back together?" :-D :rofl2:
Yes, I have Richard :-D
I'm only doing the camboxes as I've already stripped an ES9 with 170K under its pistons and I could still see honing marks on the bores so I'm not going looking for things I'm sure don't need doing...
The donor engine has only done 200K and is as sweet as a nut 8-)
DHallworth
x 161
Unread post by DHallworth »
CitroJim wrote:It helps that I already know my Activa has all the wiring in place for it...
You're bloody lucky then!!
My Activa had none of the wiring in place for the cruise control. I bought a brake pedal switch from a 2.5 XM for mine which apparently will sort it out, if I can find it I'll pop it in the post.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8422
David, that'll be absolutely lovely, thanks :-D
I noted the presence of the wiring when resolving a foglight problem last year..
I'm staggered yours did not have the wiring in place :shock:
DHallworth
x 161
I put my head in the footwell and looked up the brake pedal, there's no wiring there, I looked behind the dash for the wiring for the switch, nothing there either, and when looking under the centre console there was nothing for the ECU there either :(
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1469
Jim's activa is a mk1 with comfort and winter packs, I imagine that the harnesses have provision for everything.
Chris570
x 36
Unread post by Chris570 »
Even a goblin teasmaid
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 8422
Chris570 wrote:Even a goblin teasmaid
:rofl2:
x 3296
Don't forget the bread making and baking facilities!
Chris570
x 36
Nah that's the s2
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
DHallworth
x 161
You should get your Activa done before the Northern in May, Jim!
I'm going to bring my Activa down rather then the XM this year... There could be a gathering of V6 Activa's!!
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8422
DHallworth wrote:You should get your Activa done before the Northern in May, Jim!
I'll bring my Activa Daid but it'll still be TCT powered. Unless I retire from work right now and concentrate on the conversion full-time from now until May there's no way it'll be done :(
Next May will be an entirely different matter though :wink:
