Merged Lexia & Diagbox threads
- x 6945
Re: Merged Lexia & Diagbox threads
A bit late responding as our C3 has decided the front offside coil spring is due for replacement, so duly snapped this morning! Just been out with the mech to try and get what's left of the bu**er to stay in place with a few wooden wedges, just to get the car onto the flatbed!
MikeT
- x 232
Ouch, Marc, sounds painful. But what's a coil spring?
In contrast to my struggles - umpteenth time lucky, here!
It works (on the 17" laptop, using virtualbox with xp 32-bit). I saw the graphs. I then exited Diagbox (and saved the session) but alas, the reports tab still shows empty. I know I can view saved parameters but it needs to be connected and in-session with my car to get to that menu.
MikeT
- x 232
With Oracle Virtualbox, there's a Device > USB menu (Right CTRL + HOME if it's hidden) that shows USB devices plugged into the host. Simply select which one(s) you want.GiveMeABreak wrote:..... the USB driver support (or lack of it) in any sort of virtualisation setup.
nono03260
Re: FS: Original Actia Peugeot Diag2000 Workstation
Hello.
excuse me for disturbing you.
I also in pocession of a diag2000, but unfortunately I do not have the cable pr37, obd.
I wanted to know if any of you could test me one of these cables to tell me the continuity of it.
For example pin 1 obd, pin 3 pr37.
It would be super nice.
Sorry for my spelling, I am French and do not speak English well.
- x 6945
Hi and welcome to the Forum.
Have a look at this topic and see if it is what you were looking for:
viewtopic.php?t=49045
nono03260
Good morning Marc.
I have previously watched this topic, but unfortunately it does not match what I'm looking for.
I am looking for the diagrame of the original pr37 cable from peugeot.
This is a 37 pin cable with an adapter to switch to 16 pin OBD or 30 pin EOBD.
Thanks for your interest in my problem.
- x 6945
No problem - if you don't have the cable there is one here that looks like the one you want:
http://www.ebay.com/itm/322315560101?rmvSB=true
Is this any good?
http://pinoutguide.com/CarElectronics/p ... nout.shtml
Here's another image of the pins:
https://i39.servimg.com/u/f39/14/77/57/30/van10.jpg
Is this any good?
- x 6945
Do you want the information for the Evasion (or Synergie in the UK) in your profile? If so. post or send your Vehicle Identification Number here or via Private Message and I will see if I can find anything else. If it is for the evasion, I will need the RPO number and this is usually located on the front right hand front wheel arch (passenger side for a left hand drive vehicle).
demag
- x 102
So finally no rain. Laptop in car, connect up and Diagbox wants me to activate but there's no manual option only internet. I already activated on installation. Now what?
Sent from my Wileyfox Swift using Tapatalk
Dave
- x 6945
If it is asking to check for updates, press the red X. It should be activated already, so if not, explain what you did after installing 7.01 (after the restart it auto patches to 7.02). Did you activate it then? If so, restart the laptop and then open diagbox and make sure network adapter is switched on beforehand.
- x 6945
- x 6945
If you are worried about it connecting to the Internet, just disconnect from the wireless network connection to the router, but leave the network adapter switched on.
demag
- x 102
I'm going to reinstall. Just running CCleaner. I hate this program with a passion! It's more complicated than hydropneumatique!
Dave
- x 3296
demag wrote:I'm going to reinstall. Just running CCleaner. I hate this program with a passion! It's more complicated than hydropneumatique!
While it may be more complicated than hydropneumatique, NOTHING is more arcane!
- x 6945
Dave - it is important that the network adapter is active whilst installing and that ALL pop ups and firewall requests are allowed through. If not the activation will fail every time.
