Merged Lexia & Diagbox threads
x 6956
Re: Merged Lexia & Diagbox threads
What browser and version are you using Mike? They moved over to an HTML5 implementation from V6 on.
MikeT
x 232
Unread post by MikeT »
GiveMeABreak wrote:What browser and version are you using Mike? They moved over to an HTML5 implementation from V6 on.
Whatever's default for Window7 Home Premium, I guess? What Browser(s) should it use?
ETA: That'll be IE8.0.7601.17514 (though I've just now hooked it up to begin the great Windows Update.... I may be some time).
Also bare in mind, I previously had the same issue with fully updated Win7 Ultimate, using the latest Firefox version.
x 6956
Yes, got that Mike, I really don't know what else to suggest, I still think the Netbook hardware maybe borderline. Shame you can't put it to the test by installing on another system.
MikeT
x 232
That's a suggestion I can go with. I have a 17" acer (i3 16gb mem) I could test it on, Marc. It's not an option for permanent use due to extreme size and awful battery time.
x 6956
Agreed but at least it would show there's nothing wrong on the software side. Let us know how it goes!
x 3303
I am running my Easy Diagnostics rev B Lexia on a netbook with 2GB RAM and Windows 7 Starter (I am not sure what version of IE is running).
x 6956
Yes but are you getting live data and graphing? Mikes netbook may be borderline for graphing live data.
x 1938
Unread post by Paul-R »
MikeT wrote:... I have a 17" acer (i3 16gb mem) ...
That amount of memory implies a 64 bit operating system. Unless you can run a 16 bit virtual system Diagbox will not work properly.
x 6956
Diagbox will be fine Paul, but not Lexia, which itself is a 16 bit app. We only need to test the live data functionality and the C5 II should be fine on Diagbox.
x 3303
I have never had to try the graphing function, so I do not know if my netbook would manage it. I should give it a try sometime.
x 1938
GiveMeABreak wrote:Diagbox will be fine Paul, but not Lexia, which itself is a 16 bit app.
Meant to write Lexia (and presumably PP2000 as well) - my bad. Which brings me to...
GiveMeABreak wrote:...the C5 II should be fine on Diagbox.
Is it optional whether one uses Diagbox or Lexia on the Mk II? When Deian came round a couple of weeks ago I used my old Lexia on his Mk II car.
x 6956
I think there is a choice offered depending on car year and Diagbox software version. For some newer cars it may not be offered as a choice as they stopped updating the 'Lexia' app. I recall before I had my own kit, that an Indy garage where my ex Citroen tech worked used his 'Lexia' on my X7, he didn't have Diagbox at the time. I still have the screen dumps of the BSI configuration before he updated it via the PSA servers. It clearly shows the Lexia interface. So a MKII C5 should be fine.
x 1938
GiveMeABreak wrote:...my ex Citroen tech worked used his 'Lexia' on my X7, he didn't have Diagbox at the time.
Yes, my Lexia (which must date from about 2008 - 9) has an option for the X7. I haven't dared put it on my car yet though!
x 6956
Mine is an earlier model though Paul, but personally I always use Diagbox as I find I keep pressing the wrong buttons in Lexia, having to revert back to the keyboard, just like my pal Scotty!
cancunia
Unread post by cancunia »
Happy to be corrected on this & don't want to muddy the water too much here, but thought it best to mention in case it makes a difference to further testing that afaik Lexia is a 32bit app. WinXP is a 32 bit OS and runs 16bit apps under a kind of VM (NTVDM). You can check if you have 16 bit apps by running the task master (Ctrl-Alt-Del) and looking at the running processes, under 'options' there's a tick box to show 16 bit tasks. I ran Lexia & PP2000 and did not see a 16bit flag. As I don't have any 16bit apps that I know of, it's hard to be sure what one looks like under task master :-) If Lexia is 32 bit, chances are that Diagbox is too.
Back to the graphics problem reported earlier, does it need Java?
