RT6 2.75.c.5 Firmware / Software Download
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
x 1946
Re: RT6 2.75.c.5 Firmware / Software Download
Unread post by Paul-R »
There's an example in this post of a label showing that, in this case, 2.80 was fitted.
viewtopic.php?p=876079#p876079
Conversely this post shows a label that doesn't have the version printed.
viewtopic.php?p=876015#p876015
It is known that you cannot revert to an earlier version of firmware once a later version has been fitted. Whether that will be the same for a failed installation is not known.
marion69120
Unread post by marion69120 »
Hi!
I have the black screen on my 308, i'm used to fix the rt6/rneg units but this time I'm stuck.
New SD Card 16gb, tried 2.86 through USB with no luck (no screen at all), same with 2.80
I noticed on my unit that the CD marking is linked to the 2.75 so I tried finding 2.75 files but seems like it doesn't exist.
I only have the 2.77
This time (with the 2.77) the unit finally "boots" and shows me the peugeot logo with a "CRC Checking" but it ends with a "CRC Error". Tried different usb etc but it is still doing the same. Atleast I know it is "working".
I want to try installing with a CD but the CD player of my unit is actually dead.
I am also thinking my 2.77 files are broken or missing some files. Could you send me also a link of the 2.77 version? @Paul-R
marion69120
marion69120 wrote: 26 Sep 2026, 13:34 Hi!
just a quick update, after deleting weird files from my mac, .DS_Store etc it now pass the CRC check but i get stuck after "Disk check.." "Error during flasher loading". I tried multiple sd cards, I want to try a Sandisk but I don't have one atm. I tried Kodak, PNY and Hiksemi... Also tried the original Sandisk SD card but it is faulty and I still get the error
x 1946
Macs are notorious for dumping a load of hidden files and folders onto removable drives. It's best not to use one if possible but, if not, then all of them need to be deleted. There are apparently programs that can do this. If you're manually deleting them on your card using your Mac can you see the hidden files and folders?
Check your PM in five minutes for 2.77.
ThomasP
Unread post by ThomasP »
Hello,
I have a problem with my 2013 Jumpy Multivan. The multimedia screen stays black or lights up without displaying anything, and the CD player keeps searching continuously.
I removed the SD card and tried reading it on my PC, but it is unreadable. I suspect it may be faulty.
I tried flashing the system with version 2.86, but unfortunately, it didn't work. Would anyone happen to have version 2.77, which is the original version installed on my vehicle?
Thank you in advance for your replies, and I wish you all an excellent day!
Best regards,
Thomas
x 1946
@ThomasP
Check your PM. Usual disclaimers. Use at your risk, No warranties, etc.
Fredo2b
Unread post by Fredo2b »
Good evening. I ended up solving my microsd partition problems which systematically crashed regardless of the firmware. The culprit was the microsd, in fact only the SANDISK brand works. Impossible to find in 8 GB, I managed with a 16GB installed as is, without formatting. It just goes to show that not all cards are alike. In any case, a big thank you to Paul for his kindness.
x 1946
Thank you for letting us know of your successful outcome. Glad I was able to help.
