Merged Lexia & Diagbox threads
falling-out-with-my-car
x 25
Re: Merged Lexia & Diagbox threads
Unread post by falling-out-with-my-car »
I checked the cooling fans in high mode and thought that a jumbo jet was approaching from the east at low altitude.
Sent from my GoFone_GF50X using Tapatalk
x 25
As much as I have knocked the computerisation of cars over the years its very clever very clever indeed.
elma
x 287
Unread post by elma »
falling-out-with-my-car wrote:As much as I have knocked the computerisation of cars over the years its very clever very clever indeed.
Yep, that's one of the reasons I argue with modern cars. My car should not have a higher IQ than I do and if it does it should fix itself.
Sent from my Walkie Talkie using Tapatalk
Lucianman
Unread post by Lucianman »
Hello guys,
I'm looking to buy a lexia3 today and I wanna know if any of you have any idea about this particular product from ebay
https://www.ebay.co.uk/itm/261751630895
So I can make sure is working on my C5 1.6 Nov 2009
Cheers
Sent from my iPhone using Tapatalk
x 6963
Personally I would be very wary when buying from the bay, unless you know or have a recommendation from others as you really don't know what you are buying. The key issue is the hardware components inside the unit. A lot of the ones on the bay are not full chip units, only for the buyer to find out at a later date when it will not work with some or all of the car's systems.
I and many others here have bought from Easydiagnostics. They are the full kits and have a great support backup for buyers - more than can be said for some sellers on the bay. Your choice, but be advised.
http://www.easydiagnostics.co.uk/#/shop ... e/11022604
x 25
Lucianman wrote:Hello guys,
Cheers
That's why I went straight to easy diagnostics, so many horror storys from ebay products some even have games in them.
I would not advise that you upgrade to version 8 from the second dvd supplied and yes it will cover your C5 it covers MK1, MK2 and the X7 C5 models up to 2015. Price at the moment is £118 plus postage.
x 25
Re: I got lost at the end of my setup video
hi, can anyone clear up for me how to save my lexia activation code details to my desktop in windows 7 please I cant seem to find the file it should be in on my C: drive.
any help would be very much appreciated.
I wrote it all down first time around but when I upgraded to version 8 not knowing I wouldn't be able to activate it, I had to start again and the activation code changed then I forgot to note it down. second time around. #-o
thanks .
Nigel.
x 6963
x 25
Thanks Marc,
that's great. windows 7 says its a system file and cannot open it.
x 25
if its starting and running well but the lexia says it has an injector fault
do you believe it or not?
demag
x 102
Unread post by demag »
Didn't you get the offer of a screen dump on install?
Sent from my Wileyfox Swift using Tapatalk
Dave
x 25
No, and I sat and watched the whole process, for two installs.
x 6963
falling-out-with-my-car wrote:Thanks Marc,
You don't open it Nigel, just copy it to a safe location, then if you ever need to activate your system again after a deactivation, just copy the file back to the same location. Don't try and open it with anything, otherwise it may alter the licence code and will be useless.
x 25
Oh S*** looks like I'll need to reinstall then if things go wrong.
Lucianman
Thanks a lot guys for your guidance into purchasing a lexia. I've ordered mine for easydiag now and I'm waiting for the delivery. Thanks once again
