Driveshaft intermediate bearing
AndersDK
Unread post by AndersDK »
Clean (rub) the mating bearing and housing surfaces and smear a bit of alupaste on. Then its like Shane's world : falls out next time [:)]
johnlyn
Unread post by johnlyn »
Thought much the same whatever is alupaste is, will probably use copper grease
AndersDK
Copper grease (copra slip, CUpaste, etc) will probably make it stick again [:)]
Alloy + copper + steel is not a good mix [:(]
That's why a use Alupaste (Aluminium grease, alu slip, etc) on alloy surfaces. It's much the same product with aluminium powder instead of copper powder.
DLM
Unread post by DLM »
This is interesting. In the course of replacing the second BX octopus in a week (different cars, thankfully), I seem to have found 2 wildly different cars. Old 19RD/TGD - r/h drive shaft more or less fell out in the way Shane describes. 19DTR auto - r/h driveshaft reluctant: held in by a tin retaining lip on the differential housing.
Will be looking at the diff housing again for the bolts...
x 94
Unread post by citronut »
i hope your not taking out drivshafts to replace the octafeline thing,thats cheeting regards malcolm
