Hydraulic Pipe End Fitting
AndersDK
Unread post by AndersDK »
Must be a tubular seal there.
And the pipe end must be a straight cut - no flaring.
The pipe is double flared approx 10mm from the pipe end - such the union nut can grip on the pipe circumference.
Exactly as depicted on schematic above.
If you can slide the union nut over and away from the pipe - then the pipe is the wrong type.
x 94
Unread post by citronut »
citroen dealer is prob right as i have found some xantias do not have usual citroen pipe end,they do have flared end same as brake pipes on non citroen cars regards malcolm
zzf00l
Unread post by zzf00l »
Should collect new pipe today... will let you know
Cheers Ian
zzf00l
Yep, you live and learn....no rubber seal
FrenchLeave
Unread post by FrenchLeave »
Well done, Malcolm. You were a voice crying in the wilderness with nobody taking any notice.
zzf00l
lol
AndersDK
Well -
I stand corrected [:I]
- had no idea the pipe into the regulator could be yet another type.
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citronut</i>
as i said earlyer some of the pipe ends on xantias are flared may be just pump end regards malcolm
Both the output pipes on the two output pump on my Dad's 1994 2.0i SX Auto are the large flared type with no seals. We havn't had a reason to remove the other end of the pipes to see what type those ends use however...
Regards,
