YES - pressure on system with suspension on highest setting helps avoiding the rear cylinders turning when force applied to spheres.
Besides it always seems to help crack the spheres loose. I'd say even 1/4 turn is very close to the LHM fuzzy spray point [8]
Buy/rent/loan a decent heavy duty strap (NOT chain !) type sphere removal tool. Using an oil filter removal tool is a time (& money) waster.
IMPORTANT note : if replacing an antisink (rear accu) sphere, the pipe MUST first be unwinded from rear of sphere, before turning the sphere !
Xantia rear height,THE END
np
AndersDK
np
Rear is now buggered.Sitting all the way down,will not rise at all now on any setting.Wont b taking it to Westroen,as its undriverable.Brakes are also very on/off now(when they work!!)
Had a look underneath earlyer when i could still raise the car,all dry,no leaks anywhere.Looks like i`ll have 2 do it myself,or take it to a local specalist.
np
Back off holiday now.Car now at local specalist to fix.Gonna replace all spheres and anti sink valve.Rear wont lift at all on any setting,so had to take mudflaps off to drive!Brakes alright though.
They seem to comfirm everything that has been said on here,so thanks all 4 help.Should get car back mon,so will let you all know the outcome.
goodier
np
Got car back today.WOW!What a difference.New accum+sphere,new rear height corrector.Rear now sits as high as other ests,much more than before.Rear doesent sink when engine turned off.Sit in the boot,& she rises instantly.Much faster and smoother rising & lowering.Garage did`nt replace other spheres as said they did`nt need doing(honest of them!!)After driving it home, it`s the best its been in the 2 1/2 yrs i`ve owned it,nice & smooth,excellent ride.Well pleased.
Thanks all for help.
