Well now! I am fairly sure the HDI is supposed to operate like previous Xantias, ie both fans in series (low speed) or both parallel (high speed). I think mine (HDI 110) does, but it is difficult to check in a temperate climate (currently 13C here, and rain), unless by fooling the ECU.
Unfortunately, the coolant temperature is measured by a NTC thermistor connected to the ECU, not the previous simple thermostats. Details are given in the Revue Technique for the Xantia, but unfortunately look a bit suspect. The table of resistances stops at 80C, surely wrong.
For what its worth, here are the top 4 values (between pins 1 and 2 – 3 is warning light);
40C – 2600 to 2710 ohms
50C – 1770 to1830 ohms
60C – 1220 to 1270 ohms
80C – 620 to 636 ohms
I suspect the wrong table has been copied in. It might in fact be swapped with the fuel temperature table, top 4 values as follows.
60C – 557 ohms
80C – 273 ohms
100C – 143 ohms
120C – 80 ohms
Anyway, you could try substituting a 1K potentiometer if you are handy with electrics, and adjust though the travel to simulate the range of temperatures. I doubt it would do any harm, but perhaps avoid zero ohms (eg put 47 ohms in series). If you are lucky, the ECU should output the corresponding fan commands (and if not you will have a fault light due to incompatible values!).
Let us know how you get on, it may be very useful information.
Fred
Rad Fans not working
Clogzz
- x 40
DickieG
- Monaco's youngest playboy
- x 33
Hi Fred,
Thanks for your reply, the way I've been testing the fans speed is by using an actuator test with my Lexia, if its confirmed that both fans on a HDi should run at high speed together I'm tempted to work around the "problem" by way of using a fourth relay
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DickieG
- x 33
That's what I think, what I can't work out is why the ECU doesn't send a signal/earth to trigger the O/S fan, I know that the same connection works as its the same contact that turns on the fans at slow speed, confused? Yes I am!Clogzz wrote:![]()
If there’s no high speed for both fans, then there’s no need for three relays at the front.
One fast fan at one end isn’t as good as two slow ones blowing through the whole cooling surface, least of all as emergency cooling for the air conditioning condenser.
The engine ECU doesn't have any faults recorded (its that ECU which is used via Lexia for actuator tests) the only question mark I have lingering in the background is that the A/C ECU regularly has a recorded fault of "Recirculatory motor fan speed irregular" or similar. As fas as the A/C goes I've replaced the heater fan and ECU but that fault still appears whenever I carry out a fault code reading. According to the Citroën diagnostic manuals the radiator fans are controlled by the engine ECU and not the A/C, I've carried all the tests listed in the manual and all are correct
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Clogzz
- x 40
Looks like the HDi’s aircon pressure sensor then goes to the engine ECU for lack of a Bitron.
If the ECU’s high speed output can be trusted to feed three relays at the same time, you may plumb a diode from there to its relay 1 output to restart it … quicker than plumbing in a fourth relay.
thorter
- x 45
Perhaps the Lexia only sets or clears the discrete output for each relay separately. That would make sense for diagnostics. So the fans may well work in tandem in the real situation that the water temperature is over 107C or whatever.Thanks for your reply, the way I've been testing the fans speed is by using an actuator test with my Lexia, if its confirmed that both fans on a HDi should run at high speed together I'm tempted to work around the "problem" by way of using a fourth relay
You should be able to simulate that by the method I suggested, assuming you have the bits to do it. It should in fact be quite safe, since the ECU software can be expected to cover survival in fault situations, eg when the water pump has failed.
Fred
DickieG
- x 33
The mystery is now solved
instead of using my Lexia to trigger the fans at high speed I removed the blue connector form the sensor on the thermostat housing and both fans operated at high speed together
so after a weekend of dismantling the car and head scratching it was working correctly all the time
Doh!
Thanks for your help and suggestions chaps, I've now learned something extra about Lexia actuations
You were right there Fred, well donethorter wrote:Perhaps the Lexia only sets or clears the discrete output for each relay separately. That would make sense for diagnostics. So the fans may well work in tandem in the real situation that the water temperature is over 107C or whatever.Thanks for your reply, the way I've been testing the fans speed is by using an actuator test with my Lexia, if its confirmed that both fans on a HDi should run at high speed together I'm tempted to work around the "problem" by way of using a fourth relay
Fred
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1507
So can you test the other fan with the Lexia...?
I managed to get the fans on high on my HDi once - couple of years ago, sat in a traffic jam on a hot day at 30°C (yes, even in Scotland some times!) SWMBO didn't want the A/C on. When we got to melting point she gave in and I put it on. Water temp was around 100°C at the time. A minute or so later, there was a huge roar and the fan(s) were on high - I can't say for sure both were running, but there was a huge roar, and the whole car was vibrating, so I rather think both were running
Levo
Re: Rad Fans not working
hi there, I have xantia 2.0lt 16V petrol engine year 1999. I have overheating problem bcoz my cooling fans are not coming on even the engine is hot (90C). however when I remove the brown sensor plug, after a delay both fan goes to high speed. But as mentioned the fans dont go to low speed for a second or two. Would you pls help me how to solve this problem.
- x 1487
If the A/C is turned off, or not fitted, the fans should come on at low speed at an engine temperature of about 95°. They should switch to high speed at about 105°.
Are you getting the engine hot enough to test this?
