Thank you very much for your valuable information. Can you share the link to the topic related to remediation?
SM-N9000Q cihazımdan Tapatalk kullanılarak gönderildi
Xantia fall down then open the door help me
Re: Xantia fall down then open the door help me
The car is in soft mode when the door is opened. After 30 seconds it is still hard.
I tried to upload video for my problem.i didnt upload it [emoji35]
- x 666
Not quite sure what you mean by that, can you clarify ? Are you testing with the engine running or turned off ?mustican05 wrote:The car is in soft mode when the door is opened. After 30 seconds it is still hard.
http://cloud.tapatalk.com/s/58a22404b92 ... WA0018.mp4
This is my problem
- x 5743
There was a similar issue here in this topic, only this was happening on the rear:
viewtopic.php?t=22423
Re: RE: Re: Xantia fall down then open the door help me
Thanks for reply.[emoji106]GiveMeABreak wrote:There was a similar issue here in this topic, only this was happening on the rear:
While the vehicle is not running and running. In both cases the same resultMandrake wrote:Not quite sure what you mean by that, can you clarify ? Are you testing with the engine running or turned off ?mustican05 wrote:The car is in soft mode when the door is opened. After 30 seconds it is still hard.
Dear friends
Brain control was done today. Everything is solid. But the problem continues. I removed the brain connector and used the vehicle on that tab. The vehicle was harder. I think the brain is constantly in sports mode due to erroneous data. Do you have any other idea? And tested with a different brain, the result is the same.
Dear Mandrake
Can you show me in detail how the diode connection is made? Please help me.
I want to use flying carpet now. On which conditions should I check which fuse box or relay connections?
- x 16
If I remember right the suspension should go into hard mode when a door is open.mustican05 wrote:I think it is a mistake in the data going to the suspension. My car should be in soft mode whatever my car is under 24 km.If the vehicle has been lifted or lowered or the door is opened when the vehicle is still running, the vehicle responds to the same drop.
No when a door is open the car is should softHomer wrote:If I remember right the suspension should go into hard mode when a door is open.mustican05 wrote:I think it is a mistake in the data going to the suspension. My car should be in soft mode whatever my car is under 24 km.If the vehicle has been lifted or lowered or the door is opened when the vehicle is still running, the vehicle responds to the same drop.
What is the process done in this picture? And the diode used is there anyone who knows what?
