hi,
i have a mk2 xantia with an electric mirror on thye passenger side and a manual one on the drivers side RHD is it possible to put an electric mirror in the drivers side like my dads mk1/
meexi
drivers mirror
Hi, does the handbook refer to the electric/manual mix? Seems an odd combination. To fit two electric mirrors you will need the selector switch connections too. All of these are just under the inner door lining below the mirror. Take a look under both sides and compare the sockets available. At a guess, and it is only that, the cabling will be there for them. Remember too that they are most probably heated.
You can generally lift away the inner lining with great care just enough to get a look at the connectors by starting at the point nearest the mirrors. Good luck and take care with the lining[;)]
Easy to sort out. First remove the drivers mirror trim to check if wiring is in place if so fit new electric mirror and then switch. Have done this on 2 Xsara's with no problems. Switch from Citroen £10 with the vat and the mirror (genuine part) from GSF £75. No problems with paralell movement or any thing like that.
