My front left door speaker has either blown or has a bad connection. How do I access the speaker to check on it? Do I have to remove the entire door panel, or can I get to it easier (by just removing the JBL cover?)?
If I have to remove the entire door panel, how do I do this? I understand it's clipped on, but I don't want to break anything trying to pry it open.
Thanks!
Citroen C5 2005 - Front left door speaker
- x 36
Being a C5, check that the volume’s balance hasn’t gone to the right by itself.
You unclip the speaker grille from about 10 o’clock, then it becomes obvious.
There are four recessed black torx screws to remove the speaker.
The top ones are well hidden and need a torch to see them.
2002 C5 2.0i AL4 230,000 km 76372389
