hi i was wondering if anyone could help me. i have a 97 laguna estate and i have a knocking comming from the front when ever i hit a meduim bump in the road. i have had the suspension checked and all is fine. i was told that it is possibly my front left drive shaft that has worn. is this possible that it would make a noise like this, it really sounds like a worn bush but there are none worn atall. any help would be great.
cheers[xx(]
knocking on laguna
I've had the same problem now for several months. The knocking started off on the left hand side of the car, so had lefthand side shock absorber, drop link and strut mount replaced. This had no effect.. Now the knocking comes from both wheels, that is until I go over a bump with both wheels at the same time eg. A speed hump. And then it makes no knocking at all. The only thing I haven't checked is the anti roll bar bushes, but, they can't be replaced on their own. You have to replace the whole anti roll bar, as the bushes are not seperate.. When I get enough cash together I'll replace the ARB, but Renault seem adament that it is the bushes on the wishbones?????
