Xantia steering rack
I need a new rack for my xantia 1999 1.9TD i have located one on ebay and they are giving the following part No DSR580 AMK cross ref pt No Ts1075
do these numbers mean anything to any one? and is it right for this model year? as there are two types of rack, any help would be most welcome, Thanks
1999 Xantia Estate 1.9TD
i need the last 8 digits of the chassis/VIN No.,
not your RP No. which is 4 digits,
the play is probably the track rod inner joint and even though i have not fitted one myself, im sure they are replaceable,
i will get you the part No.'s for the rack and the inner track rod ball joint,
then you can deside which way you want to go,
retgards malcolm
retgards malcolm
The rack will be more than an average X reg HDI goes for, the inner joint £28 ish, there is an issue with the rack in that the N/S of it is supported by a splined nylon bush within the rack housing and they can wear and are not available seperatly, but they will not knock usualy, the early xm ones were metal bushed and they did rattle when theyt wore though.
I would also have a check and make sure the rack mounting bolts are tight, it has been known for them to work free and cause a rattling.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
You DO NOT have to change the whole rack!!
You CAN change inner ball joints with track rod as an assembly....
Ive done this on XM's before now, I used a Good Mole grip, pulled back the inner rubber boot which was tight, and unscrewed it...
Daammmmm sight easyer then a rack swap...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
It IS a Quick Fix! I did the XM in half an hour! A rack swap is a MASSIVE job... Steering colum off, UJ joint off, track road ends off any way, disconnect PAS feed pipe and Fluid return pipe, DROP THE Subframe for enough clearence.....
So the rack swap is NOT a quick fix... Track control arms will be!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
If you follow the track rod from the hub towards the rack, it goes into an inner Ball Joint... This joint unscrews directly off the rack end.... Theres no inner parts inside the rock to touch...
Theres just a rubber cover over the inner jjoint. It IS Very tight, had to use mole grips....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Possibly - or a scrap car - the rods are quite easy to check for play.. Grasp and pull/push....
I had mine from spare racks I had removed from cars Id dismantled..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
http://www.frenchcarforum.co.uk/forum/v ... highlight=
Maybe you can remind me Paul! What's the deal with the inner washer
where the inner balljoint meets the rack's end - I cannot recall what the
Xantia design is like here as I've worked on Xm, Cx, Gs/A etc and there
are varied permutations? This doesn't have a peened over tab on a locked
inner washer onto a shoulder of the inner BJ?
It''s been around 6-7 years since i needed to change an inner bush/track rod
so I'm a bit rusty but recall having to get the multi ridged inner washer from
Citroen Prats.
BTW, I wouldn't use second hand when new on Citroen are very reasonable!
Andrew
Citroen Prats.
Andrew
