Hello,
im looking for information on the LCD display used with RT3 and RT4 radio headunits. The manual (for 307 2004) list it only as DT display.
RT3/RT4 LCD display info
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: RT3/RT4 LCD display info
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
To Upgrade Your Membership & Donate Click Here For Further Information About Vehicle Parts and VIN Numbers Click Here |
Hello Marc,
the part number is 6563 (EG).
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I don't understand what you want. The display units are entirely different between most telematics units and most require a specific model to be compatible. Rt3 has an optical connection, others use LVDS, there are different resolutions (Low Res / High Res) and some Head units require a High Res screen to work.
I want to know who manufactures the screen with the part number 6563 (EG), that is compatible with the RT3 and what screen the RT4 and RD4 use.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Well that's not a valid part number. But as I said that info is not available from Citroen, you'd have to check the back and see if it has a label.
6563 (EG) is listed as the lcd part number for a Peugeot 307 break here https://catalogs.ssg.asia/peugeot/?lang ... aWVyPT0%3D.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's old data 10 years old. PSA do not supply their data any longer online to auto suppliers like this, so that part has been replaced and no longer available.
That doesn't change the situation - the information you require is not available from official sources - PSA don't provide this sort of info in most cases apart from the part number.
So the only way to get this information is by forum intelligence (people who had the part and are repairing or replacing it).
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
And there won't be many of those now given that spares are rarely available for these old systems on the second hand market now, but good luck.
