https://www.ebay.co.uk/itm/221866711982 ... SwOdpXzFyx
Please see the first post on this thread:99xantia wrote: ↑26 Nov 2021, 20:33Hi
I’m lacking on ability to find a parts catalogue I can download anywhere so can anyone tell me the correct part number for an external temperature sensor for a 1999 Xantia 2.0L HDi 109 please.
Any pics/part numbers would be great. I don’t even know where to look for it! I’m new to the Xantia.
Many thanks.
If it's item (7) - The Accelerator Pedal Sensor, then it was part number: 1622F2, but no longer available from PSA and I can't see anywhere from a brief search. So is it worth contacting a specialist to see if it can be refurbished?Mark Graham wrote: ↑26 Nov 2021, 20:16Hi all,
looking for help on a throttle position sensor for my Peugeot 605 2.1 auto. Reg number t184twk Really struggling to find one, im not sure if it would be shared with the xm?
I did manage to find a used one online but it was from a manual car and its different on an automatic.
Rear subframe, Chief.GiveMeABreak wrote: ↑27 Nov 2021, 11:03I'm not sure exactly what you want - the subframe shows no flexible mounts - so are you referring to the engine mounting?
If anything here, let me know the item number.
This baby please!GiveMeABreak wrote: ↑27 Nov 2021, 15:28There isn't any rear subframe listed - that 's the issue - so what do you want? Rear hubs / Rear Axle or rear bump stops for the suspension? It's an issue of terminology I suspect.
