Hi
I have a 2010 3008, the boot has all of a sudden stopped unlocking therefore I cannot open it. The fob and the interior unlock button doesn't open it. Is there any way I can get it back open? Is there a fuse that may have blown preventing the solenoid from working?
3008 boot not unlocking/opening
- x 744
Re: 3008 boot not unlocking/opening
If you look on the tailgate latch here in the little slot there is a little arm you move with a small screwdriver that will manually release the tailgate latch so you can get it open to do some investigation. First port of call would be to check the wiring where it goes from the body to the tailgate, as this part flexes all the time its a common braking point of the wires.
