2013 Peugeot 208 XY E-HDI Engine Fault on Start.
wobblewoo
Post by wobblewoo »
Hello all, thanks for your time.
I have just inherited a 2013 Peugeot 208 XY E-HDI and have an engine fault on start. It starts and ticks over fine, theres no rough idle or anything. The car had been sitting for 6 weeks or so but did start up fairly easily. Someone who knows the car said it was being driven with this fault for a while but i need to sell it so would like to make it as good as possible. I cannot drive the car.
I got the RAC to scan it and they gave me the following faults. I was going to get a can of 'CleanDrive" and put it in the fuel as this seems to be injector related.
Any directions or help would be gratefully received. Many thanks. Wx
Code: Select all
System Type: ENGINE SYSTEM TEST/VALUES
Name: 9HD - SID 807
DTC: P0266,cylinder 2
DTC: P12A5,cylinder 2
DTC: P050B,Starting time too long
DTC: U1134,Communication on LIN. No communication with the voltage retaining device
System Type: BRAKES
Name: ANTILOCK BRAKING SYSTEM/ELECTRONIC
STABILITY PROGRAM - ABS/ESP
DTC: C1391,Engine torque non acknowledgment
System Type: CENTRAL ELECTRONIC UNIT
Name: BODY COMPUTER - BSI
DTC: B1163,Numberplate light
DTC: B162C,Accessories positive (+ACC) relay output fault
DTC: B1805,Starter motor
wobblewoo
Re: 2013 Peugeot 208 XY E-HDI Engine Fault on Start.
Post by wobblewoo »
Anyone?
x 1030
Post by RichardW »
Looks like it needs a new No 2 injector....
