Hello,
I have a Peugeot 407, 2010 with RT5 WIp Nav. I want to put a rear camera but i want to put the screen automat in the video mode when i put the gearbox in R. Anyone succeeded that?
or i have to buy an interface for this? I saw NG4 it made for that.
Many tks for your answer,
rear camera on RT5
Moderator: GiveMeABreak
- x 5781
Re: rear camera on RT5
The NG4 didn’t support a rear view camera. Some later models of the RT6 did as well as later telematics systems.
Sorry i guess i made a confusion: in fact i talk about this : https://www.car-interface.com/vendita/e ... d-ng4.html
- x 5781
That link is for a unit that states it is compatible with a Navidrive 3D (NG4) system. In the description below, it also states it is compatible with the RT5, so they say it should work. There is a fair bit of wiring to do though....
Marc,
the only thing i want is to not put before the radio in the video mode and then to put in R position. I want to put automat. As i understood this interface can do that, because as I know RT 3,4,5 don't have a rear camera wire out to link the red wire which it comes with the camera.
That is the only reason. I was just curious if someone did that!
Hey did you manage to do that? I have the same problem and I would really appreciate if you share some info.
Thank you
Thank you
