Good evening all,
New bluetooth module fitted today on my Nemo 2015. Does anybody know how to change the language on it as its currently spanish.
How do i change language in Bluetooth? (Nemo 15)
Moderator: GiveMeABreak
Reason: Moved to the Telematics Section
- x 5850
Re: How do i change language in Bluetooth? (Nemo 15)
Bluetooth module? For what and where did you buy it from? It's a little vague from your description, so if you can expand and provide some more detail that might help.
Bluetooth module was brand new supplied and fitted by main dealer yesterday.
- x 5850
You mean this?
That's the telephone interface if this is what you mean. Otherwise I don't know what you're referring to as Bluetooth is not a device - it is just a communication protocol like radio waves or wireless. I.e. Phones, cameras, watches, dash cams, GPS, mp3 players can all communicate via bluetooth, but bluetooth doesn't tell me what the device is.
If this is a telephone interface, then the module should allow communication with your phone via the head unit that you have. I'll need a VIN to see what you have though.
No Marc it's the black box that was fitted under the drivers seat.
Cheers
Cheers
- x 5850
Do you have the part number (should be on the invoice) that will helo me as I can't tell what you have had fitted.
Sorry don't have an invoice as it was replaced under warranty.
- x 5850
Ok, so I can only suggest you go back to them and ask them to sort out the issue you have then as they fitted it.
Thanks for the advice but think I will live with it. The garage is 150 mile round trip and i've been there 5 times to get the flashing odometer and bluetooth fixed. I was hoping someone on the forum would know how to change the language, worth a try.
- x 5850
The only thing regarding language is generally on the head unit itself. But you haven't provided me with the VIN yet so I can't help you further as I can't tell what system you have.
Just been on a Fiat forum for a quick look regarding language settings. Looks like the software for Blue and ME needs updated with the English language. I have downloaded an update for Fiat but no joy. I am unable to find a Blue and Me update for Citroen.
Glad my car is a BMW as this French stuff is too complicated.
- x 5850
That's the issue - it's not actually French!
If it was the systems are a doddle to update as a rule - all done via a USB or CD - but you have a FIAT. But the dealer should of done it for you - it's a shame you are so far away from one though.
Thanks for your help Marc. I never had a good experience with the dealer and hope I never need to go back to them.
I asked them if my van had a timing belt or chain and when it's due to be changed. They couldn't find any info on the system and i still don't know!
- x 5850
If you have the VIN I can probably look it up for you, but if it is the 1.3 HDI 80 engine, then I believe this is by chain only, so if a standard belt would be every every 70k to 100k miles, then you should be godd for at least this long.
Hi Marc, Here is the VIN. VF7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot
Thanks a lot
