guys
i have bought an aux cable and connected it to the back of the radio.
it didn't work apparently i have to use the obd port and menu selection cd & aux 1 to enable the aux.
I was looking for a obd2 cable to usb and get hold of diagbox to do it.
But i just messaged this guy https://www.ebay.co.uk/itm/122026499846?ul_noapp=true
and he told me that this won't work with diagbox.
Anybody know which cable or software i will need.
cheers
citroen c8 blaupunkt rd4 radio aux input
Moderator: GiveMeABreak
- x 5828
Re: citroen c8 blaupunkt rd4 radio aux input
You’ve got it all mixed up by the sounds of it.
Basically what you need to do is enable the CD Changer port on the Head Unit. This was for the optional CD Changer.
To do that you will need to get somebody with a Lexia or Diagbox diagnostic kit to enable this for you as the Head Unit ECU has to have the CD Changer parameter enabled.
There’s no such thing as an OBD to USB cable.
The OBD port is what the diagnostic kit uses to talk to the car in order to change the option above.
Remember the CD port can only mimic functions of a CD Changer.
- x 6
thanks for the response Marc
this is what I'm trying to do
I was under the impression that i could get a cable that plugs from the obd2 port to USB on the laptop and run diagbox/lexia on that ?
I have that CD changer cable plugged in now just want to do the other part ?
Reason: YouTube link
- x 5828
Yes, got, that, but these are 2 separate things. You can do the first part, but you need a laptop, diagnostics kit and the software and the knowledge to be able to change the setting.
Have a look at the Lexia owners on this site to see if there is somebody who will enable the option for you:
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
There is a map at the end of the post showing the member locations on a Google map.
- x 6
cheers Marc
that's very helpful indeed there is a guy fairly close to me i'll msg him
best regards
best regards
- x 5828
Ok, just remember not all members are active on the Forum all the time, but fingers crossed.
The option will be in the Head Unit RD4 ECU.
Hiya. Not sure if this is a good idea – to jump on an old thread or start a new one – but I'm trying to do the same as above. So I have already fitted the cable, and now need to find someone with a Lexia / Diagbox to have the CD Changer parameter enabled. I'm trying to contact a member through the list of Lexia owners above, but I can't seem to do it. perhaps because I'm a new member? Anyway, I'm located in West Sussex, so if anyone can give me any advice, it would be appreciated!
Just to add, since I wrote the above, I've had my first post (this one!) let through by the moderators. And now I am able to contact people on the Lexia list.
