After installing a few updates from the initial install of 7.02 the software now won’t close. After each update (am now on 7.57) i was able to close Diagbox ok after it installed the “internet updates”, but then after restarting the laptop & then opening Diagbox again - when I try to close it just says “Closing of the application in progress, please wait” .... & half an hour later it's still trying to close.
I thought that perhaps any updates would cure this but it appears thats not the case. I have a Rev C full chip interface & Win7. Doesn't make any difference if I have the interface connected or not.
Only way to close is with task manager. I take it it's not safe to use with the car if its not shutting down properly ?
Diagbox not closing
- x 33
Re: Diagbox not closing
Hmm
I have yet to figure out how to update mine. I have a phobia about letting it connect to the net.
Now I'm worried about messing with it at all. It works at the moment...
Sparksie
2000 Xantia 1.9TurboD
- x 5841
These aren't internet updates - it's just what it says on the screen! As long as you have your network adapter enabled , but no live connection to the net you are fine.
Max - make sure that windows update is not getting re-enabled after startup and anti virus software - that will interfere with updates. Disable the services for now until everything is installed.
- (Donor 2017)
- x 5
Cheers Marc, had to turn the firewall off as well as Windows update & now it closes fine. Phew.
- x 5841
If you don’t allow the firewall requests it may interfere with future sessions, so important to allow all these through Max.
- (Donor 2017)
- x 5
Funny because I did allow all connections as & when it prompted & the updates installed fine it was just closing it that was the problem. The only way to get it to close was turning it off completely. Maybe just a glitch on my particular machine. Thx
